20 Most Recent Samsung YP-K3 MP3 Player Questions & Answers
It's not a hard work that you can have a try powerful program Leawo Tunes Cleaner. Leawo Tunes Cleaner is a professional duplicate music remover.
Step 1. Run Tunes Cleaner and Scan Duplicate Songs
After kicking off Leawo Tunes Cleaner for Windows, click the "Clean-up Duplicates" entry. The program provides 2 duplicates scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
Step 2. Add Music Files for Duplicates Removing
You could delete duplicate songs in iTunes music library by directly clicking "Scan iTunes" button or click "Add"button to load music files for duplicates removing. Or you could directly drag music files from your local folder to the software for duplicates removing.
Step 3. Start Deleting Duplicates
After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
tunes-cleaner-scan-result-gwujvob1wsqcwi5j4bnkubbk-3-0_3.jpg For more details, check: How to Delete Duplicate Songs
Samsung YP-K3... | Answered on Apr 24, 2019
if your samsung does not work with your computer go on the net and, type samsung bluetooth repair down load. you will be helped
Samsung YP-K3... | Answered on Feb 18, 2019
Available from Samsung suppoort site along with firmware upgrade tool
Like most Samsung electronics, the software is the pits, yet the hardware is generally quite good.
If the Samsung YP-K3 MP3 player continues to act erratically, a reboot, or reset, may help. Resetting this device allows you to reinitialize your player without losing your files or device settings.
The Reset hole is on the back of the device, toward the bottom. Press one end of a straightened paper clip into the Reset hole gently. Then allow the Samsung YP-K3 MP3 player to initialize.
You may want to upgrade and if you have, this may be why the files were reset.
YP K3 SUPPORT SAMSUNG
Samsung YP-K3... | Answered on Jan 08, 2019
What model of Recevier do you own?
Are you just connecting Audio to the recevier? How are you connect the satelite?
Samsung YP-K3... | Answered on Jan 02, 2019
Overview for all models YP-K3 in USA:
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP01&searchWord=ypk3&searchInputBox=yp-k3&find_button=See+all+results
When having a product from another region, select your country on the left bottom page.
Using Windows Media Player 11
When viewing Library in WMP11 in full mode 'Create Playlist' first, before transferring it to the player:
More information about using Windows Media Player:
How to use WMP 10:
http://www.microsoft.com/windows/windowsmedia/player/10/using.aspx
How to use WMP 11:
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Using Samsung Media Studio
Manual for the YP-K3 tells to use Samsung Media Studio for transferring files to the player, see from page 20:
http://downloadcenter.samsung.com/content/UM/200702/20070225090856671_YPK3-COMMON-ENGLISH0.0.pdf
Direct to the download for Samsung Media Studio:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=1848443&CDCttType=SW&ModelType=N&ModelName=YP-K3AB&VPath=SW/200712/20071220130654265_MediaStudio5_5212.exe
Samsung YP-K3... | Answered on Nov 26, 2018
connect your samsung to a computer usb, go to my computer, check for removable e or f , with the samsung connected go on the net and type search samsung k3 mp3 player software. the computer it self will select a software to down load.
Samsung YP-K3... | Answered on Nov 23, 2018
Samsung service centre is located in ameerpet, Hyderabad, in Ground floor of Elephant house. Contact No's: 040-66820252, 040-30308282, 9912237601
Samsung YP-K3... | Answered on Aug 17, 2018
look at where you got your driver some free down load driver are not compatable
Samsung YP-K3... | Answered on Jan 03, 2018
hi Zoooya.
try this.
1]Go to control pannel
2]Go to System and Security
3]Go to Device Manager
4]Click Universal Serial Bus Controllers
5]Right click the USB
6]Click Uninstall
then Reboot computer while pendrive is inserted in USB
Then connect to the internet.
When you connect to the internet if the said USB is empty
(i.e. no device is inserted in it) they install the device
even though the device is not present, causing the said error.
or this.
Try the steps below:
1. Make sure you update to latest BIOS.
2. Reinstall USB controllersFirst, please disconnect all USB devices and then perform the following steps:
a) Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
b) In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
c) Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
3. If the above steps cannot resolve the problem, try the steps below:a) Turned the laptop off, unplugged it.
b) Pulled out the battery for a few minutes.
c) Then power on the laptop.
Make sure the USB device is working, try changing to another USB port.
5. Also, you can try in-place upgrade your system or system restore from the Windows Recovery Environment (WinRE)
At boot-up, Hit F8 --> Repair --> System Recovery Options Window --> System Restore.
or this link if you need more info on this matter.
pc one of the USB device attached to this computer is malfunctioned and...
Samsung YP-K3... | Answered on Dec 17, 2017
Samsung YP-K3 MP3 Player Logo
702 questions posted
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
YP Samsung
  • YP Samsung
Most Popular Question
samsung nearest service center in
  • Audio Players & Recorders
