I found a way to show you how to enter it on your calculator. Make sure you are in Math Input Output (MathIO). To effect that press [SHIFT][MODE][1:MathIO]. Calculator clears its screen
Press [SHIFT] then [Fraction template key] the one just below [calc]. I will show an image of the template in a picture below. Then you enter 4.6x85000 in the upper square of the template. Press the [Down Arrow] to move cursor to the lower square and key in 3570x0.0843. Then use [Arrow right] to move cursor to the level of the fraction line and press [=]. Hope it helps.
SOURCE: scientific notation
you want to hit mode not menu and then make sure that normal is flashing instead of SCI and hit enter. so just hit mode then enter and it should be normal
Use the EE key
1.234[EE] [(-)]65 [ENTER] 1.234 times 10 negative 65 =1.234E-65
The (-) is not the regular (bigger) minus sign.
Hope it helps
SOURCE: how to turn off scientific notation?
Press [SHIFT][MODE][6:Fix] (number between 0 an 9) to select the number of decimal digits you want. Then press [=].
Hope it helps.
SOURCE: HP 12C went into scientific notation and will not come out of it
To exit the scientific display format press the [f] key followed by the number of decimal digits you want.
Hope it helps.
Testimonial: "Yes, the answer was correct and very helpful"
You have a key marked [x10^X] located on the bottom row of keys.
Example: To enter 6.02x10^(23)
6.02[x10^X] 23 [=]
If you have a negative exponent, use the change sign key [(-)]
pls.answer
