20 Most Recent Casio FX-115ES Scientific Calculator Questions & Answers
CONVERTING BINARY TO GRAY CODE. EXAMPLE: 00011010
11111111
4/9/2024 4:19:54 PM • Casio FX-115ES... • Answered on Apr 09, 2024
My screen says DEC 0
Your calculator is in binary mode. Press MODE 1 to switch to "normal" mode or MODE 2 to switch to complex mode.
3/22/2024 3:35:48 PM • Casio FX-115ES... • Answered on Mar 22, 2024
How do you get a
Some keys have a letter of the alphabet next to them. The letters are A, B,C,D, M, X, Y. They correspond to memory registers (memory locations) in which you can store values.
To enter a letter as when you are entering an expression with variables, you press the [ALPHA] key followed by the key next to which is the letter you seek. To enter letter A, You press [SHIFT] [(-)] if I am not mistaken.
3/22/2024 10:48:02 AM • Casio FX-115ES... • Answered on Mar 22, 2024
Porpo YH-2000 2.5 inch 11 Digits Function Scientific Calculator.
Question edited to give its full 'make model (what it is)' in correct order. Question moved for Audio Player category to a Scientific Calculator one. Yes, this unit does exist but not here in North America where we are located. https://www.google.com/search?q=Porpo+YH-2000+calculator ..
12/15/2023 4:58:43 PM • Casio FX-115ES... • Answered on Dec 15, 2023
Square root in answer
Press SHIFT [SETUP] 1 to set the MthIO mode. Try calculating the square root of 8 (press sqrt 8 =). Do you get 2sqrt2?
4/11/2023 7:37:00 AM • Casio FX-115ES... • Answered on Apr 11, 2023
3answers
Mixed fractions
When you get a fraction for he answer: shift-S<->D[a b/c<->d/c]
This way, you change it to a mixed fraction or improper fraction
11/25/2022 11:30:24 PM • Casio FX-115ES... • Answered on Nov 25, 2022
4answers
Any way to make decimal answers the default? (casio fx-83ES)
you want a line output
Shift > Mode > 2:LineIO or on the graphics one its sometimes 10:LineO etc.
look for something with line in it
Steve :P
12/9/2021 3:26:33 PM • Casio FX-115ES... • Answered on Dec 09, 2021
2answers
My calculator fx-991 Es is showing either syntax
How about recreating the error and reporting faithfully the error message? You get a syntax error if you try to invert a matrix by using the wrong key sequence such a
[SHIFT][MATRIX][3:MatA][X to ] -1), meaning that you use the universal power key on the same row as X squared and log and between them.
To calculate the inverse of a matrix, have the name of the matrix on the command line, (see above) then press [X to -1] key one row up from [log].
Concerning your implied affirmation that if the matrix is square you should not be getting any error: You will get an error ( a Math error) if determinant of the matrix is equal to zero.
10/18/2021 11:46:08 AM • Casio FX-115ES... • Answered on Oct 18, 2021
F(X)= wont go off my
Your calculator is in Table Mode.
Change the mode to Computational: Press MODE, select 1: COMP.
10/7/2019 7:44:48 PM • Casio FX-115ES... • Answered on Oct 07, 2019
Simplifying radicals on fx-115ES
If your calculator is SetUp for Math Input/Output (MATHIO), a result that gives a radical will remain in radical form. If a radical appears in a denominator the whole expression is rationalized: Any radical left is put in the numerator. 1/Sqr(3) is displayed as Sqr(3)/3.
3/19/2019 9:01:17 PM • Casio FX-115ES... • Answered on Mar 19, 2019
2answers
I have too many zeros after the decimal point.
If got to do with the mode settings. Usually MODE fix in other lower version of calculator. The combination can be MODE FIX 0 for no trailing zero's if MODE FIX ONE then if will 0.0 or one zero then shifting the settings to NORMAL mode and at DEG mode.
2/11/2019 10:26:37 PM • Casio FX-115ES... • Answered on Feb 11, 2019
2answers
How do i get answers as decimals in casio fx 115 es plus
To convert a single result to decimal, press the S<=>D button just above the DEL button. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
10/30/2018 6:26:03 AM • Casio FX-115ES... • Answered on Oct 30, 2018
Which word correctly completes the sentence?
park's
5/22/2018 12:47:51 AM • Casio FX-115ES... • Answered on May 22, 2018
How to clear the memory of a casio fx-115es calculator
Reset the calculator or store 0 in each memory location A, B, C,...
4/8/2018 9:41:00 PM • Casio FX-115ES... • Answered on Apr 08, 2018
Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
1/10/2018 8:21:46 AM • Casio FX-115ES... • Answered on Jan 10, 2018
MY CASIO CALCULATOR MODEL NO
How to turn off fx-911w? I tried shift and on. Shift and AC does not work also. Please help thanks
9/18/2017 3:44:03 PM • Casio FX-115ES... • Answered on Sep 18, 2017
How do i calculate limits on casio fx-9750gii
You cannot do it: the calculator does not have a Computer Algebra System (CAS).
9/11/2017 5:03:25 PM • Casio FX-115ES... • Answered on Sep 11, 2017
2answers
How do you turn off the fraction output. I want
When you have a fraction output, press the [S<->D] key to convert to decimal, the same key to convert from decimal to fraction. Beware that fraction results are exact, while decimal values are approximate.
However if you cannot stand the sight of a fraction, there is a way to get rid of this type of output.
Here is how you do it.
[SHIFT][MODE][2:LineIO]. All your results will be in decimal. However you will lose a lot of functionalities, such as calculating the logarithm in any base, manipulating radicals.
My advice, if you allow, is to activate the [SHIFT][MODE][1:MathIO] and press the [S<->D] whenever you want a result (be it a fraction or radical) in decimal format.
Hope it helps.
5/26/2017 7:54:22 AM • Casio FX-115ES... • Answered on May 26, 2017
2answers
Sin, cos, or tan, on casio wrong answer. another cac right answer
It may be due to the angle unit used. You can have angles in degrees, in radians, and in grads. You should set the default angle unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The values of angles calculated by the inverse trigonometric functions are in the default unit that is set . This may be the source of the wrong answers that you get.
Hope it helps.
5/17/2017 10:18:04 AM • Casio FX-115ES... • Answered on May 17, 2017
Casio FX-115ES Scientific Calculator Logo
1,263 questions posted
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
casio calculator fx 991ms giving me
  • Office Equipment & Supplies
