20 Most Recent
Casio FX991ES Scientific Calculator Questions & Answers
How to calculate mode with caso fx-991ES
MOD simply calculates the remainder that is left over after dividing by the MOD parameter.For example, 10MOD7 = 3 since you can only divide 7 into 10 once, leaving a remainder of 3.For larger numbers, eg 389487MOD31 you start by dividing 389487 by 31, which gives 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD calculation has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculators working capacity.An alternative method is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
How i can solve quadratic equations which have no real roots
If the quadratic equation has no roots, you cannot find the roots. The discriminate is negative, so if we attempt to use the quadratic equation, we get no roots.
For example, y=x^2 +0x + 3
a=1, b=0, c=3
(-b+/- sqrt(b^2 -4ac))/2a
Substituting in the numbers, we get
x= (-0 +/-sqrt(0^2 - 4(1)3))/2
x= (0 +/- sqrt (-12))/2
We cannot do the square root of -12. Therefore, there are no roots. This is the same as having no x-intercepts. The discriminant is b^2-4ac. In this case it is -12. Thus, there are no real roots.
However, you can still determine the maximum or minimum, the vertex, the axis of symmetry, the y-intercept and the stretch/compression. With this information you can graph the equation.
In this case, the y-intercept is 3, the vertex is at (0,3), the axis of symmetry is x=0, the minimum value of the function is 3.
Good luck.
Let me know if you have any questions.
Paul
The dark screen on the calculator, i can't see the numbers
Turn calculator on.
Press SHIFT Mode
Scroll Down to go to next page
Press 8, then use left arrow to dim or right arrow to darken the screen.
See the screen capture below (these are for the FX82ESPlus)
For your calculator, it will be 8 CONT
Floating-point in casio fx-991ES
Guys please tell me how can i truncate the entire fractional part (Explicit integer Type conversion) in my fx991 es calculator?it helps me a lot in solving my cryptography problems easily...
How to fix in upside down calculator screen
The calculator may have been subjected to a hacking procedure found on the Internet. Find a way to undo the hack or buy another calculator. Or hold it upside down to read the display (once you get the last result.)
Permutations
Use nPr, which is the shifted function of the multiply key. For example, to find the number of permutations of six items taken three at a time, press 6 SHIFT nPr 3 =
Integrate
Set Input/output to MathIO.
Press the Integrate key, to the right of CALC.
The image of integral appears with a rectangle for the function, and two small squares (one for the upper limit the other for the lower limit).
Type in the integrand (the expression you want to integrate) in the bigger (on your display) rectangle. Use appropriate parenthesis. To type in X press [ALPHA] )
Use the down arrow to move cursor to the square for the lower limit. Type in the lower limit. Use the Up arrow to move cursor to the upper limit square. enter the upper limit. Press [=] key. If you did not make mistakes, and your expression is not too complicated you should get your integral.
Note: The screen captures are not from a Casio FX991ES. But that should not matter to you.
Replace screen
Given the cost of the calculator, it probably will be much cheaper to just replace the calculator rather than paying for and installing a new screen.
Sin degrees
You can use the setup to set the angle unit to be degree. Press
[SHIFT][MODE](Setup) >3:Deg .See Screen capture.
Alternatively you can enter the unit (degree) in the function. Press [SHIFT][ANS] (DRG>] and select the degree unit). See screen capture
You get the same result as above. Note the degree symbols inside the function.
