Ow To Fix Your Scooter That Won't Turn On Or Charge - YouTube
https://www.youtube.com/watch?v=rgK2l6cMCc4
17 Mar 2017 ... GoGo Or Go Go power chair repair. How to replace the batteries in the sealed battery box on your power chair scooter. Battery: UB12180.
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… [email protected]
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
SOURCE: pride celebrity deluxe comfortcoach 1v problem-
Usually when a scooter dies, there is an event that preceded the dead state that caused the fault. What were you doing before it went dead?
The biggest culprit for scooters and power chairs is moisture. With a scooter, there are two components most susceptible. One is located inside the top of the tiller and it is an electonics board about 6"x4" in size. If you had the scooter out in the rain without protection over the tiller, water can encroach into this area and short the board. Or, a coke or coffee spill can short it. There's a fuse on the board and if it is blown, then likely the board is shot as the fuse merely keeps the tiller from going into a total meltdown in the event of a short. Boards run about $25.00 to $45.00 to replace. Inspect it and look for any signs of overheating or corrosive buil-up and see if the fuse has blown.
The second component is located under the shroud beneath the seat. It is a small metal box which is the power control module and it controls all of the operations of the scooter. It has several wires going into and coming out of it (on-board chargers for some scooters will only have one wire going in and one coming out, sometimes two). These boxes are water resistant, but are susceptible to damage if the scooter has been run through a puddle and a lot of water has splashed up onto it. These are several hundred dollars to replace, but first check all of the fuses coming off the batteries that will lead from the battery to this control box and insure that it isn't a blown fuse. These fuses generally don't blow unless the scooter was operated beyond its capabilities, like driving it in sand, mud or other unstable terrain that puts an enormous strain on the motor and pulling a lot of juice from the batteries. Finally, check all of the connections that clip together. Don't rely on a visual inspection, take them apart, and reconnect them all to insure a good, tight fit.
Hope this helps.
SOURCE: how do i remove the pride legend classic xl8 seat
hi, be careful here as it can make your back ache,
now there is a lever to the right of the seat, pull it up towards you and
turn your seat 90 anticlockwise, so the seats not facing the control panel, at right angles, you should now be able to lift the seat , take great care here if you have back problems in the past as some seats are quite heavy.
Regards
GeWiz.
Testimonial: "thanks"
SOURCE: Pride celebrity XL won't go.
Have you checked the motor brushes for wear and spring tension, sometimes the spring becomes brittle and breaks but can sometimes still make contact.
Regards Steve.
