E-Machines T5048 (7136) PC Desktop Logo
Posted on Sep 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to put the recovery partition back on the emachines t5048
Hi im new and i need help putting recovery partition back on the emachines t5048
Anonymous
Level 2:
Scholar:
  • Expert 85 Answers
  • Posted on Sep 15, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
85
Questions
0
Helped
30996
Points
243
As far as i know the only way is to run the restore disk from emachine that is for your model computer. (it usually wipes the computers hard disk in the process.)
the link below will take you to their support site for drivers.
on that site look for eMachines Recovery Media Purchase Program and you can see about ordering the recovery disk that you need.
http://www.e4me.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5048
I have a new computer Emachines can not get in because of passwoord need to change
Get the password from the person that put it in? You say New, is it New to you? Not one you bought , and setup out of the box? Is it a Login Password or a BIOS Password? If it's a Login Password, do a Factory Recovery, if you have a Recovery Partition. Use this procedure: https://support.gateway.com/emachines/software/MICROSOF/vista/7515910/7515910su4.shtml
Recovery partition on e528 is gone how can i get it back!?
there are many freeware data recovery programs available on the web
http://download.cnet.com/easeus-partition-recovery/3000-2248_4-75279786.html
Easeus Partition Recovery is a free and easy to use partition recovery solution. It can solve the partition loss problems including partition deleted by accident, partitions lost due to virus attack, partitioning error or any other problems under Windows both 32 bit and 64 bit operating systems http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: partition recovery you might have to try a few times to get it right
hope this helps
How do i reset my emachine t5048 to factory setting without the windows boot disc?
Some computers will have a recovery partition you can recover from it will prompt you as the computer is booting. Emachines are very low end computers and don't typically have a recovery partition. If you didn't create the recovery disc you will need to order it from Gateway's website as they own emachine.You can order recovery media from https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
1helpful
Added 2 1GB memory to a T5048. Will not boot. do I need to upgrade the BIOS? Also want to disable on-board graphics and add a pci graphic card.
There are two variants of the T5048 One uses DDR PC3200 ram the other uses DDR2 PC5300
Should be able to look at the old ram and it should say on it what it is. If it doesn't, take out the new, put in the old ram and go here http://www.crucial.com/store/drammemory.aspx Run the "Scan My Computer"
Some computers will have a setting in BIOS to disable on board video although eMachine are very low end and probably don't offer that. Shouldn't need to just install your video card and plug your monitor into it. It should work just fine without disabling on board.
Comment if you need more help
1helpful
My sound card is not installed on my computer because i did the recovery. where can i download one? it's a eMachines windows XP T Series T5048
Here's a link to the Emachine support page for your model. Scroll down to audio section and you should be able to download your sound drivers. If the sound still doesn't work after doing this download the chipset drivers and then try downloading the audio drivers again. Sometimes you need the chipset drivers first before the audio drivers will work. http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5048
Can't access emachines recovery partition
I'm not sure if this helps you but have you tried using a restore point to restore to a previous state ?
This can solve a lot of problems and doesn't lose documents.
3answers
Restore emachine
Your machine has two ways of repair: SYSTEM RESTORE and SYSTEM RECOVERY. System restore is a Windows utility that rolls the machine back to a point where the machine worked before the problem. System recovery is an eMachines tool that puts the machine back the way it was when you first got it. Restore wont delete your data, recovery will and can. If the problem is catastrophic, and youve backed up your data off of the machine, use the recovery option. Your recovery partition (or a recovery disk) is needed to do this, and it involves pressing a key while the computer boots up. Check your documentation for your model of machine.
1helpful
2answers
EMACHINE T5048
I have a dvd/rw,in my emachine, the device manager says it's working properly,yet it will not read any disc i put in it, accept a disc cleaner cd and i have cleaned the drive three or four times, when i put in a cd or dvd, the light comes on like it's trying to read it, but it doesn't, please help me, thanks
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
