I tried rebooting, which used to work. I removed and re-inserted USB and power cables.
SOURCE: Lexmark 4350 and Vista
Hi I found that you can download the drivers for vista here http://downloads.lexmark.com/cgi-perl/do... Good luck Redsocks
SOURCE: Communicating error when using battery
yes am just using my cam and suddenly that error occurs. yes am using original JVC data battery. anyways i already brought it to a jvc service center and it's already fix. they're not so clear what really happens but they got it running again after 5 weeks in their hand.
SOURCE: Lexmark X 1270 Can not Print
I may be a bit late with this but it worked for me. Uninstall your antivirus, remove any parental controls and disable your firewall. Then, reinstall the printer and download a 2008 version of your anti virus and re-enable your firewall. I haven't reactivated the parental controls just in case it all goes pear shaped.
SOURCE: Problem Communicating with the printer Lexmark
1. Try another USB cable.
2. See if you can detect it when you search for new printers in the printers folder.
3. Reinstall the printer software.
A quick fix for most communication errors can be
achieved by resetting the printer and/or rebooting the PC. Simply disconnect
the printer from your computer. Reboot your pc. Unplug and re-plug the printer
into the power source to reset it. When the printer turns on, reconnect it to
your computer. Then try to print again once the computer fully recognizes the
USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers
and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Hi Patti Keller, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
It was working at some stage ?
Can you describe what happens ?
Is it showing offline in Office programs ?
Is the USB cable plugged into a usb port on the p.c or is it in the ethernet port be mistake ?
(seen this done on Sunday)
Sorry for the questions but the more information we have the better we can assist you ?
