Kenneth Prost Posted on Sep 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Savin 917 Copies are faded on the Left side of page.
I have replaced the drum, Toner, Toner rack, Transfer Roller, Fusing unit, and cleaned the optics and any clear plastic. Granted none of these parts were brand new, but they were all from a known good unit that has a network problem. If I select to print darker, it does print the faded area darker. It is about an inch wide faded area. Happens with any paper tray and both scanning areas.
Randy Schumann
Level 2:
Sergeant:
  • Expert 410 Answers
  • Posted on Sep 15, 2019
Randy Schumann
Expert
Level 2:
Sergeant:
Answers
410
Questions
0
Helped
88084
Points
956
Kenneth:
I would remove and cover the drum carriage (to protect the drum from damage by exposure to light), and check and clean the corona wires. There is a charge corona and a transfer corona, so that's two coronas that you'll have to clean. If you can remove the coronas from the machine, you can do a better job of cleaning the coronas. A faded line down the page like you're getting could be a paper shard stuck to one of the coronas... it's been known to happen.
Testimonial: "I am failing to find any documentation on Corona wire for a Savin 917. I did stop the copier mid copy and noticed that the left side of the image transfer roller was visibly lighter than the rest of the roller. I cleaned it and it printed a bit better, but still visibly faded."
  • Kenneth Prost
    Kenneth Prost Sep 16, 2019
5 Related Answers
A
Anonymous
  • Posted on Sep 15, 2007
SOURCE: small group of spots repeating on page
Have you tried contacting Okidata, 2000 Bishops Gate Blvd.,Mount Laurel, N.J. 08054-4620 Phone 1-800-OKI-DATA(654-3282) or visit www.okidata.com I have a similar problem with my OKIPAGE 10e. 1 inch wide black line, 2 inches from right hand side of page from top to bottom of 8 1/2 x 11 pages. I also cleaned black dust off green roller. Problem continues. Conclusion: I'm not an expert, but I think your wiping, checking, and cleaning, is a waste of time. I think your problem, and mine, is probably not a hardware problem, although I removed my black toner cartridge out of curiosity and perhaps re-installed it incorrectly. My guess is it's some sort of electronic problem, such as programming error, or software problem.
Anonymous
  • 3587 Answers
  • Posted on Feb 28, 2008
SOURCE: toner marks down right side of page
hmmm...sounds like your toner cartridge is truly unhappy. I'd return it if I were you.
no worries..start by getting new driver for that here
Anonymous
  • 8 Answers
  • Posted on Apr 12, 2008
SOURCE: Faded print on left hand side of paper
This type of printing defect is normally caused by 1 of a few problems - the easier one first:
1. Toner cartridges sometimes do not have the toner evenly distributed - close the toner cartridge and inspect the hopper right below it for even distribution of toner.
The harder ones:
2. This type of defect can also be caused by dirty charging section - for the drum to pick up the toner it must be charged electrically prior to exposure - if the charge grid is not clean then it will not give the drum an even charge - not sure were this is in this printer yet - looks like it comes as part of the drum kit so this should not be causing this issue.
3. The last and most difficult to check is paper alignment with the drum - is the paper contacting the drum evenly - look for possible problems in the paper path with the drum unit removed - look for something uneven around the area were the paper contacts the drum
Joed911
JDTec
  • 4338 Answers
  • Posted on Nov 10, 2008
SOURCE: Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dick O Reilly
  • 3594 Answers
  • Posted on Mar 03, 2009
SOURCE: dirty, smuggy, pages
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
To confirm run another test page and open the lid as soon as you see the page start to exit the machine.
Remove the toner and pull the page out from inside the machine.
If the marks are on the fused portion of the page but not the unfused portion the problem is the fuser.
Fuser is readily available.
Hope this helps
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
8answers
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
A toner catridge leaked in my Canon PC921. I cleaned it up and installed a new cartridge, but now my copies are dark on one side, light on the other.
on analogue copiers, if You have dark copies, that means that You need to clean optics ( mirrors and lenses - maybe some toner get to them ) or check/clean/replace the fixing film!
Regarding poor copy, clean/vacume/change the transfer roller ( beneath the drum unit - on paper path from drawer/bypass, before fixing unit ).
Hope that helps!
1helpful
2answers
I channged toner in my sharp sf-2022 copier, now i have black smudge-like marks going across paper & the copys are real light begin to fade 1/2 way thru page? cleaned 1 of the rollers, helped a little...
Open front cover, you will see yellow knob, pull it down and pullout. Wipe the side with mesh with clean cloth and insert back. That's the main charge unit.
Pull the green lever to the left and pullout the transfer charger . Wipe the two wires carefully not to break them and insert back.
Do not try to remove the drum if you have no skills otherwise this should solve your problem.
1helpful
Hello sir i have problem in ricoh aficio 1022 image repeat problem. u told me to change hotroller pressure roller baring also i change its same plz tell me where is the problem before fusing copy is ok...
Hi sir; No matter who told you to replace, the hot roller is the most possibility, the next item also last item you need to check is drum unit (drum cleaning blade,[replace it ], image transfer roller [clean up by alcohal] and drum [ depend condition ]).
Copies fine on bottom, but fade to nothing at top
Could be one of many things. Possible new transfer roller - make sure the transfer roller is not jammed.
Check the developer roller (at exit from toner hopper), to see if it is rotating properly. Check all connections to/from drum and transfer rollers.
This is most likely a dev unit problem. Not sure if dev/hopper and transfer are all in one unit - if so, replace the lot, or you'll be chasing one problem after the other.
Print quality
For photocopiers the symptom that you have described could be accounted for by a number of things. The first step would be to determine where the problem is originating from. Dirty optics could be the main culprit. The mirrors used to reflect the image onto the drum unit can build up with dust and cause a darkening of the image or an uneven image darker on one side. Cleaning the optics will correct this. If there are bad or worn seals on the developing unit it may be spilling excess toner down one side of the page as the paper is passing over the transfer corona/roller. You can check for this by stopping the copy process before the paper gets to the fusing assembly. If the dark band is on the paper before it has reached the fuser than it is either the optics, a worn out or possibly over exposed drum or problems with the developing unit or exposure lamps if so equipped. If the copy is clean before it goes through the fusing unit then it could be the fusing rollers have worn out and need to be replaced or if lucky just the fuser cleaning wick, felt or blade is worn and needs to be replaced.
Faded left hand copies
Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
Faded line going through
Anne, This could be several things-here is a list... 1. transfer roller or belt dirty, especially if inside of printer looks like it needs a cleaning. You could vacuum with toner vacuum or take it in for service. 2. scanner mirrors dirty. would need to be serviced by a technician. 3. scanner toner shield out of position-tech needed. 4. toner cartridge needs to be shaken horizontally-toner could be all on one side of hopper. 5. the fusing section could have work rollers, they sometimes get scored and leave a strange brownish line on the page that sort of fades if you print multiple pages. Again, tech would be needed. Anne, thanks and good luck.. Thanks and good luck...
Top Savin Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Ngoro
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
