1997 Saturn SL Logo
Posted on Sep 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wiring diagram wiring tell lights
ZJ Limited
Level 3:
  • Saturn Master 17,989 Answers
  • Posted on Sep 14, 2009
ZJ Limited
Saturn Master
Level 3:
Answers
17989
Questions
0
Helped
14459226
Points
60858
1997 Saturn SL 1.9L MFI SOHC 4cyl
1991-98 Starting, Charging, Fuel Pump, Cooling Fan, and Headlight Schematics
1995-98 Stop Lamp and Turn Lamp Schematics
1991-98 Marker Light Schematics
1991-98 Back-up Light and Daytime Running Light Schematics
I hope help you with this. Good luck.
I changed light asembly light will not work is there a relay somewhere it is 1996 f150
What light assembly ? tail lamp , headlamp etc.... Couldn't tell you without know what light assembly ! Have to look at a wiring diagram ! You could check it out yourself ,go to http://bbbind.com/free_tsb.html free wiring diagrams ! click on wiring diagrams ,not TSB'S . Enter your vehicle info . year ,make ,model engine size ! Then under system click on lighting , then under subsystem click on which ever yours is , interior or exterior ! Good luck !!!!
Can anyone tell me why my dash lights are all off? Tried the ground wires not the problem. Can it be the fuse or relay?
Usually not a relay ! Could probably tell you if knew what make , model an year vehicle . You need to do some electrical testing to say for sure . Find a wiring diagram at http://bbbind.com/free_tsb.html free wiring diagrams ! There are videos for automotive electrical testing on you tube , how to read a wiring diagram , voltage drop testing etc.... If you have to ask on here your probably better off taking your vehicle to a qualified repair shop . Finding electrical faults is best left to a pro !
Can anyone please tell me which wires to splice together from my xdvd110bt to my 2007 Chevy malibu I'm following the diagram posted on other sites and Im left with a green wire and am short a grey wire. My...
Carefully go back over every wire connection making sure that you didn't miss a wire color in the dim light under the dash.
Follow the wiring below.
Here is the official wiring diagram -
http://www.dualav.com/support/manuals/xdvd110bt.pdf
Tail light wiring diagram
Any parts store can tell you the correct bulbs for your Civic. Chilton manuals have wiring diagrams, most libraries have them. Some libraries are on line, so you can find them on your home computer. You will need a library card.
Wiring diagram for electric windows
just use a multimeter or a test light, a test light can tell you what wires are hot and a multimeter can tell you what had continuity to ground.
8helpful
2answers
I need a wiring diagram for fog lights oem to my toyota
The link below is a Typical fog lamp / driving lamp hookup. Keep in mind that in most states, for these lamps to be 'legal' (and thus pass inspection), you must wire them such that:
1. You can cut them off (in other words, there must be a switch installed to turn them off)
and
2. They may only be operated with the low beams. (therefore, you must power your on/off switch from the low beam circuit)
http://www.accessconnect.com/fog_driving_lights_wiring.htm
Trailer light wiring harness
try http://www.etrailer.com/faq-wiring.aspx. They have very good concise information that might help.
1helpful
Dash lights dont work
sounds like you probably just blew a fuse , check your fuses , there should be a diagram on the fuse pannel cover that tells you what each fuse is for.
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
