Jiangsu Starlight Electricity Equipments Co Ltd manufacturing and selling 3 75KVA 3125KVA low noise and mobile diesel generator set we also supply gas generator Our cooperation...
Turns out it was the Manual-off-Auto switch that was bad. My DVM showed a voltage drop across the switch. The controller wasn't getting enough power.
One good thing about it was it forced me to really study the schematics to understand how everything worked. I'm now in the process of designing my own esp32 based controller, with wifi connectivity, to replace the stock control board.
See following link https://www.generac.com/service-support/product-support-lookup
Check fuse and connections between start switch, control board, and starter solenoid.
ENGINE CONTROLLER CIRCUIT BOARD GENERAL: The engine controller board is responsible for crank- ing, startup, running and shutdown operations. The board interconnects with other components of the DC control system to turn them on and off at the proper times. It is powered by fused 12 VDC power from the
It is possibly a transfer switch issue, not the generator control board. Have an electrican kill utility power, let it start and run, then disconnect the sensing wires in the ATS. If it stops problem is ATS
is engine running at 3600 to 3700 rpm at full load. most small engines run at this speed.you can buy a small tach on ebay TINY TACH.. you have to know what the engine speed is
You have a problem with the carb float valve. It is no longer sealing causing fuel to continue to flow into the float bowl after it is full. It may be dirty, out of adjustment or just need to be replaced because old and worn out.
Have you checked the fuse? Mine keeps blowing the fuse (located on the back of the control panel) with each startup and shutdown or use of idle control.
