Dryers Logo
C
Carl Crawford Posted on Aug 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NEED to put a belt on dryer - Dryers
Poppa Maddo
Level 2:
Sergeant:
  • Expert 372 Answers
  • Posted on Sep 03, 2019
Poppa Maddo
Expert
Level 2:
Sergeant:
Answers
372
Questions
0
Helped
118783
Points
687
Which brand and model of Dryer?
Ronald Rissel
Level 3:
Master:
  • Dryers Master 715 Answers
  • Posted on Sep 02, 2019
Ronald Rissel
Dryers Master
Level 3:
Master:
Answers
715
Questions
Helped
259090
Points
1075
Gotta take it all apart (including removing the drum) to be able to get the new belt on. Unfortunately, you did not give the brand name or model number, so I can't tell you how to proceed, but in most American models, you remove or lift up the control console, then the dryer top, then the front, and then the front bulkhead. You may not have to actually remove the drum, but you might be able to feed the new belt over the drum, but then you have to re-connect the idler wheel by feel, and if you've never done that before, then it is time to call a professional appliance repairman.
Need help with putting dryer belt back on Maytag newer dryer
which side of the dryer is the belt that turns the drum and how to put it on.
2helpful
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
4helpful
2answers
Amana dryer belt has come off, need to put back on, Help....
Here is a pictoral of a variety of different BELT CONFIGURATIONS for dryers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
1helpful
1helpful
Need to know how to replace the belt on my dryer
Take off front and put belt over drum. Reinstall front. Take small access panel off back to install belt on motor. Idler pulley pushes against belt to tension it. Thanks, please leave feedback or contact me again for more info if you need it.
Put a belt on a dryer
Hello vanessastar3. Your dryer may have a motor mount with cushion or spring mounts and they may have grown weak with age. If the dryer performes substantially this maybe the lose point. Check your belt route most units have a flate spring supported roller and this maybe your weak spot. I will need Mgfr. & model# to be more pin point to the problem area if these suggestions don't correct the problem. Have fun.
Oct 01, 2008 • Dryers
Top Dryers Experts
john h
