Some depends on weather or not not your sink w
As coated or not but sanding the finish may help.
Do NOTuse steel wool on stainless as it will leave particles embedded in the stainless.
Try 400 to 600 grit sandpaper on an area to see if the contaminated metal will be removed. If this works for you try to use the finer grit in all areas of the sink to blend it in.
The acid has already "etched" your sink so you can't remove those marks, they're probably permanent.
They are not dirty.
SOURCE: How to Install Stainless Sink Baskets?
The stainless steel basin had a pair of big holes in the bottom, suitable for attaching strainer baskets or a garbage disposal. The basket comes with a black rubber gasket that seals underneath the basin, a thick paper washer, and a die-cast metal lock nut to clamp the basket onto the basin. There is also a smaller lock nut that connects the sink tail-piece (the first part of the drain system) to the basket. You should apply a bead of clear silicone to the rim of the opening. Also apply a small bead of silicone to the underside of the edge of the basket. olding the basket by the center, set it in the hole and gave it a slight turn to spread the silicone slightly. Down Under: apply a thin layer of pipe thread compound (a.k.a. pipe dope) to the larger diameter threads. Few plumbers use thread compound here, but I believe in lubricating threads whenever possible. There have been so many times that I needed to remove a basin lock nut, but was unable to because of the slight corrosion that inevitably forms there. Thread compound would prevent this problem. The metal lock nut, the rubber gasket and the paper washer were installed, turning by hand most of the way. The only practical way to tighten these huge lock nuts is to use a pair of 18" jumbo Channel-Lock pliers. To hold the basket from turning, use a pair of screwdrivers placed in an X-formation in the little holes. The lock nut must not be over-tightened, or the rubber gasket can be squeezed out of place, which could cause a leak.
SOURCE: SCRATCHED STAINLESS STEEL SINK
Try contacting Prime Time Solutions 1-800-333-9525. They have products for all sorts of problems with stainless steel sinks. I called there with my "scratch" problem & their representative, Elaine,who is very knowledgeable, gave me a couple of avenues to take. She even sent me a free small sample of Flitz to try. I liked the product so much I ordered some from her.
SOURCE: I need a new franke
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
SOURCE: How to clean the stainless steel stove top
Someone else suggested Easy Off Oven Cleaner (I used fume free). I just finished using the Easy Off (make sure you cover the electronic ignition) with Q-Tips and my top looks almost as clean as when I first got it.
SOURCE: I cannot clean my Samsung
when you clean the stainless make sure you wipe with the grain and not across it.
