20 Most Recent
Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and Questions & Answers
How to turn on shower head of Delta monitor
I'm at my cousin's place and he has a delta monitor. Similar to what you guys are talking about.
To turn on the shower, I had to pull down on the faucet head, not the shower head.
To turn off the shower, I had to push the faucet head back up.
Hope this helps anybody out.
I have a delta 1400
I had the same problem. My building manager showed me that you have to yank the circular portion at the end the of spout where the water comes out downward and the water will be diverted to the showerhead.
I have a Delta push down bathtub drain stop, but
There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
Lift and Turn:
The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
Toe Tap:
The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
Good afternoon, We have a 25yr old delta shower
You don't change the setting on the faucet or behind the shower wall. You change the mix in the hot water heater itself. New hot water heaters are set at a relatively lower hot-water-setting for liability purposes. To achieve a hotter mix, take the cover plate off the hot water heater. You will see a dial setting that allows you to turn up the heat. Depending on what type of water heater you have, there might be two cover plates (lower and upper). If so, you'll need to adjust both of these.
Delta pull-up bathtub drain problem
Hi Bigoz,
Drop the drain plug down about half way and try turning it counter clockwise. If you get no resistance after a full turn you will probably need to cut or break it out. If the pin is missing I'm guessing this is what you'll have to do. This answer assumes you have a lift and turn style drain.
Please ratre this response and Good Luck, Phil
My shower monitor valve keeps losing presure
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I don't know how to open the shower. It only works
Hello. At the bottom (spout) where the water comes out it have a pull button. Just pull it up and water should comes out trough the shower head. If water comes out without pressure and is partially comes from the bottom just replace the spout. (bottom part)
I have a barely used delta monitor 1300/1400
Take the handle off and then there is a flat plastic washer... take that off... behind that there is a plastic stop that is very difficult to move, but with some work you can turn that and then push it back in to give you hotter water...
heatman101
