20 Most Recent Hayward EC-40 DE Pool Filter with pump Questions & Answers
0answers
De leaks into pool
one or more of the grids may be damaged. you will have to open the filter and inspect the grids (yes, they will have to be cleaned for the inspection)
3/17/2016 12:15:54 AM • Hayward EC-40 DE... • Answered on Mar 17, 2016
2answers
How do I backwash my Pentair Vertical Grid DE filter?
For instructions on backwashing and other trouble shooting, you need an Owner's Manual. You can find one online at the following link:
http://www.pentairpool.com/pdfs/FNSPlusVerticalGridDEFilterOM.pdf
The way you backwash this filter is easy once you get the hang of it!
The first thing you will do is turn off the system, change the valve position to the Backwash position. If you have a Multiport Valve, you will press down on the handle and spin it so that the knotch is pointed to BACKWASH. If you have a Slide Valve, only has two positions, up and down, you turn the handle so that the metal pin is out of the holder and move the handle in the opposite direction. You will need to turn the handle to lock the pin into position.
Once this is done, you will turn on your pump. Pentair recommends that you backwash for 1 minute, then turn off the pump.
If you have the Slide Valve, you will put it back into the FILTER position and then turn the pump back on for 1 minute. If you have the Multiport Valve, you will put it in the RINSE position and then turn the pump back on for 1 minute.
Pentair recommends that you do this cycle a total of three times, backwash/rinse, backwash/rinse, backwash/rinse. AFTER the third time, you will need to open the Air Release Valve at the top of the filter while the pump is OFF and the valve position in back on FILTER. Once this is done, turn on the pump. When you have a steady stream of water coming out of the Air Release Valve, close that up. This way you have no air in the system.
Now, you will mix your DE "Slurry" in a bucket. Depending on your model of filter, you will measure out your DE and mix with water to the consistancy of milk. **IF it is just a backwash, you will only add 80% of the original amount of DE. You only add the total 100% of DE when you completely take the filter apart and clean it out.**
You will slowly pour the slurry into the skimmer that is closest to the pump. This will allow the DE to evenly coat the grids in the filter. Wait about 5 minutes and then check the pressure gauge on the filter. Once the PSI reaches 8 to 10 PSI above this number, it is time to backwash.
5/13/2015 10:19:23 AM • Hayward EC-40 DE... • Answered on May 13, 2015
Why hayward pump with quik disconect emerson 1hp leaks from top
Replace the O-ring.
9/28/2014 5:43:46 AM • Hayward EC-40 DE... • Answered on Sep 28, 2014
3620 hayward de filter earthe coming back to pool
take filter apart examine all the cloth elements if torn or ripped replace and that should fix your problem
8/30/2014 4:46:58 AM • Hayward EC-40 DE... • Answered on Aug 30, 2014
Dirt comes back in pool after vac even though I backwash
take filter apart see if the cloth grids are torn if so replace that will get rid of redepositing
8/30/2014 4:40:53 AM • Hayward EC-40 DE... • Answered on Aug 30, 2014
Why is my pool pump not pumping, only humming
had the pump running at 1 point without being primed and burnt the pump motor up.
7/18/2014 4:15:21 AM • Hayward EC-40 DE... • Answered on Jul 18, 2014
2answers
Pentair Quad DE system was installed without multiport valve
This is a DE (Diatomaceous earth) IT doesn't have sand and doesn't backwash. You use the bump handle (with pump off and valves closed and vent open and drain dirty water/earth out) Here is a link to the manual for your filter If isn't the exact model they are all on their web site: http://www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
6/24/2014 12:18:48 PM • Hayward EC-40 DE... • Answered on Jun 24, 2014
Hayward EC-40 DE Pool Filter  with pump Logo
Popular Tags
84 questions posted
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Hayward Pool & Spa
  • Hayward Pool & Spa
Most Popular Question
pressure goes up after 2 hours
  • Pool & Spa
