The lens is not completely flush with camera body, extending some 3 - 4 mm out. Lens cover is very slightly open. Lens error 22 appears in LCD screen.
Two possibilities: one bad, one not so bad. If you've recently dropped the camera you've likely damaged the lens tube (housing), and the camera will require professional repair. Before you panic though, the problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem may be due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
