20 Most Recent Konica Minolta DiMAGE G500 Digital Camera Questions & Answers
0answers
Cannot take so much pictures. what is a memory
A memory stick generally refers to a USB device that you use to transfer digital media from one device to another. Your camera would utilize a memory card - depending on your camera this could be a CF card (bigger almost square) or a SD card (looks like a SIM card.As to the number of pictures you can take: This depends on a number of things - 1) Internal memory of the Camera 2) Size of your memory card 3) Settings you shoot with.Depending on the camera you have you can set the quality and type of format - format could be your camera's raw capability which is usually the largest size to save an image in or it could be set to JPEG (here you normally have settings like Fine, Medium and High or Small, Medium, Large) some cameras only offer JPEG output and will only show you the option to set it on small, medium or large.Smaller size = More photos, but keep in mind that this affects what you can do with the photo. If you want to use it for the Web or mobile then small is no problem, if you want to print the photo then a medium (preferably large) setting should be used.The best is to have multiple cards and then you can continue shooting even if you are not at a place where you can download what you have already.
8/30/2013 6:23:54 AM • Konica Minolta... • Answered on Aug 30, 2013
I need to READ the battery charger instructions for a Minolta Dimage G500?
I suggest you charge the battery overnight and in the morning if the LED does not change color then the Red LED on the charger only indicates that there is mains power to the charge adapter.
7/12/2012 7:42:56 AM • Konica Minolta... • Answered on Jul 12, 2012
Cannot get date to print on .jpeg images when downloaded
The date and time (and a lot more) are stored with every photo in its EXIF metadata. If you want the date printed on your photos then please refer to the documentation for whatever program you're using to print. Depending on the program and printer you may have the option of printing the date on the image, in the margins, or on the back.
4/19/2012 5:22:46 PM • Konica Minolta... • Answered on Apr 19, 2012
After i plug into usb
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
7/4/2011 5:40:15 PM • Konica Minolta... • Answered on Jul 04, 2011
Minolta Dimage G500 digital camera.
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
4/27/2011 2:58:46 AM • Konica Minolta... • Answered on Apr 27, 2011
System error S00042 message lens cover won't close
I Hope the steps below should be helpful in fixing your camera issue.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
2/4/2011 7:49:37 PM • Konica Minolta... • Answered on Feb 04, 2011
Camera dropped - lens jammed
This is such a common problem that someone has written a blog just addressing this one error. You can read it here - it describes it far more completely than I ever could!
2/3/2011 9:58:57 PM • Konica Minolta... • Answered on Feb 03, 2011
How can I get the user's manual?
You can download the manual at
http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-g/dimage_g500/D_G500_E.pdf
1/27/2011 3:22:01 PM • Konica Minolta... • Answered on Jan 27, 2011
I want to know how
Repeatedly press left/right on the selector to bring up the self-timer mode (one-handed clock). Start the self-timer by pressing the shutter release button.
Refer to pages 38-43 of the manual for further details. If you need the manual, you can download it at
1/26/2011 5:59:15 PM • Konica Minolta... • Answered on Jan 26, 2011
I lost the user's manual of this camera. How do I
just google what you are looking for cam make and model followed by users manual and dutch and you may be surprised
1/25/2011 9:03:12 AM • Konica Minolta... • Answered on Jan 25, 2011
I bought a Kingston 4GB Class 6 SDHC Card for this
The G500 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
11/5/2010 2:53:08 PM • Konica Minolta... • Answered on Nov 05, 2010
My camera will not accept
You need to format the internal memory with no card in the camera. Once it is erased, your card should work properly.
10/14/2010 8:54:01 PM • Konica Minolta... • Answered on Oct 14, 2010
Camera displays a 'no card' message, tried
There is a couple different things you can try. One is to clean the memory slot contacts with a cotton swab or rubbing alcohol and a cotton swab. You can also check your camera setting to see if the memory options let you switch to memory card. You should also make sure none of the cards are locked. It is possible that the camera needs a firmware update.
9/10/2010 2:10:59 PM • Konica Minolta... • Answered on Sep 10, 2010
Lens does not extend when lens cover is open
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
6/28/2010 7:26:43 PM • Konica Minolta... • Answered on Jun 28, 2010
2answers
G500
Might it be that what you refer to as "reset the memory" is actually format the memory, that is erase all its content and lay down a new, fresh, clean system?
If yes, then in the SET UP menu, select FORMAT and press right, select media type (what ever memory it is you can cleaned/formatted), press either right or MENU/SET button. To confirm select YES with left or right and press again the MENU/SET button. Once it starts to format " Now FORMAT" displayed would be shown with a graph at the bottom indicating how much of the memory has been formatted and how many more to go.
If no, pls post back what is displayed in the screen.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
2/2/2010 7:07:13 PM • Konica Minolta... • Answered on Feb 02, 2010
Konica Minolta DiMAGE G500 Digital Camera Logo
56 questions posted
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Bill Eager
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
View Most Popular
DiMAGE Konica Minolta
  • DiMAGE Konica Minolta
Most Popular Question
camera dropped lens jammed
  • Cameras
