Dirt Devil CE6000 Featherlite Wet/Dry Vacuum Logo
Posted on Sep 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wet dry vacuums and shampooing rugs
Do the wet dry vacuum cleaners do a good job at shampooing your rugs
Anonymous
Level 3:
  • Master 867 Answers
  • Posted on Sep 02, 2009
Anonymous
Master
Level 3:
Answers
867
Questions
0
Helped
335674
Points
2689
They do ok, but a dedicated wet/steam cleaner does better
1helpful
WILL i HARM the hardwood floor under my Area rug to be shampooed. No pad underneath
Simple answer: YES
Anytime you are sampooing anything the under surface will be exposed to the cleaner. Move throw rugs to a location safe for the cleaner. Kitchen floors are usually good for this or a concrete floor. Remember to let carpet dry completely before replacing it. It will be lighter when dry so easier to move. But as a glass on a wood side table leaving a ring a wet carpet can leave a shaped stain.
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Have a D4 model rainbow vaccum cleaner and want 2 no how 2 shampoo with it please help me
put cleaning solution into the proper receptacle lower brushes making contact with the surface to be cleaned. turn the on off switch on. start at the edge of the carpet squeezing the trigger for cleaning solution release and pull backwards.release trigger. roll vacuum back to begining position and pull backwards without squeezing solution release trigger. push back to the top slightly overlapping the first pass and repeat procedure. after rug is been completely shampooed allow to dry. after rug is dry sweep with broom
Feb 26, 2011 • Vacuums
Can I use Rug Doctor steam cleaner shampoo in my Ultimate G series Kirby carpet shampoo system?
The answer is no. This type of shampoo doesn't work as well in the Kirby. It should be dry foam shampoo only.
Using the bissell proheat upright carpet cleaner and no shampoo is being dispursed.
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
1helpful
Lost our directions for our Bissell 1698-Q rug cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
h
Bissell proheat 2x rug cleaner wont spray water out on rug when you press button
heatman101
USERS INSTUCTIONS FOR OXY PRO BISSELL CARPET SHAMPOO CLEANER
heatman101
dsfsgh
Need replacement for shampoo bottle on eureka atlantis
I googled Eureka Vacuum Parts and found 1-888-209-8113 svcvacuum.com (USA only)
Top Dirt Devil Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
NOEL
NOEL
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
