Garden Logo
J
James Carter Posted on Jul 17, 2019
I need a battery for my Power Glide hedge trimmer
5 Related Answers
Anonymous
  • 163 Answers
  • Posted on Nov 28, 2008
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Anonymous
  • 4 Answers
  • Posted on May 24, 2009
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Anonymous
  • 986 Answers
  • Posted on Jun 17, 2009
SOURCE: Expand-It Hedge Trimmer Parts
Belive it or not there is a nice selection at Homedepot.com
Anonymous
  • Posted on Feb 18, 2010
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Anonymous
  • Posted on May 29, 2010
SOURCE: ECHO HC-1500 hedge trimmer wont stay running cuts off
Replace the fuel cap.
I need a battery for my Power Glide 18-inch cordless hedge trimmer
You should be able to find a replacement battery by doing a google search. Batteries are available.
Jul 17, 2019 • Garden
Craftsman battery 300210
A negative temperature co-efficient (NTC) thermistor. A thermistor monitors the temperature of the battery pack during charging.
I need to purchase AC/DC adapter direct plug-in class 2 power unit, model 60101272/SH-DC200400 to recharge my battery powered Power Glide portable hedge trimmer. Could you let me know where I could order...
It this the one you are looking for? Amazon has it for about $18.00 on Prime.
Hope this helps.
Jaye
https://www.amazon.com/Power-Glide-Battery-Charger-Base/dp/B00OJLPWQI
Feb 14, 2018 • Garden
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
I need a new power pact.
If you are looking for the battery, here is the information Power Glide® 18v Cordless Trimmer Battery (60101271)http://www.acehardware.com/product/index.jsp?productId=2463050
Power Glide® 18v Battery Charger (60101272)
http://www.acehardware.com/product/index.jsp?productId=3497457&cp=2568443.2568444.2598675.1327540.1260415
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Trimmer Question
mains, battery or petrol A hedge trimmer can be powered in 3 ways: mains electricity, rechargeable battery or petrol. They all have their advantages and disadvantages, so decide which is best for you. Electrical hedge trimmers provide a clean lighter weight option with the convenience of immediate and continual use. However you may be restricted by cord length - not ideal if the hedge is a long way from your power source and having a cord can be obtrusive and dangerous. Rechargeable hedge trimmers give you the best of both worlds. They're clean to use and have no cord so they can be used anywhere, without the danger of accidentally cutting the cord. They are less powerful than petrol models and you do need to plan ahead though and make sure your batteries have been charged. 5-7 hours of charging will give you just 30 minutes use. A second battery will give you back up but if you're cutting for long periods of time, you may find this timescale too restrictive. Petrol hedge trimmers can again be used anywhere, there's no cord so they're safer. Just top them up with petrol and away you go, no charging necessary. These models do tend to be harder to use - they're heavier, noisier and smoky.
Top Garden Experts
Jay Finke
Jay Finke
john h
