My kenmore upright freezer is tripping at the breaker. it runs for a a couple of seconds.you can hear it run then trips the switch at the outlet
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
Do you have a meter that reads amps and continuity? If so I can help you diagnose the problem.
yes
