Most have a one-time thermal fuse wired into the motor. You would have to remove cage and fan blade, unscrew motor mounts, open motor casing, locate fuse by cutting open or sliding off the thermal sleeves, cut fuse out and resolder a new thermal fuse in. Should be able to locate replacement thermal fuse online. Can also just splice ends together but then you lose thermal protection and a fire can result. It is a good temporary fix to diagnose if you have burnt out one of the motor coils.
I would remove the outer fan shroud and then the blade assembly. Lay it on a lot of news paper and spray grease lighting on it then use soft bristle brush to clean it wash it off in bath tub set outside to air dry then reassemble. Don't use on electric motor.
I'm not all up on Patton Model#s, but this is an older unit, correct? You may try contacting Patton (Owned by Holmes now so you may have to go through them)
If they cannot help you, try www.dtvintagefans.org There's collectors there that may have parts fans that they may be willing to sell a blade.
Alternatively, you may try Grainger, as they sell an assortment of blades. You will need to match a blade to your motor though, which should be fairly easy as the Patton fans use a common McMillan motor which most attic fans also use.
The fan blades have to be balanced for it to run smoothly. This website looks like it's straight from 1995, but the instructions are good and you should be able to rebalance your fan without too much trouble.
I have a metal blade for the Patton U2-20 fan listed on ebay. The item number is 160273949463 and the listing ends on Wednesday August 27 at 10.00 p.m. I had this fan for 8 years and the motor has failed. Patton could not replace the motor since this is a discontinued item, and I figured that someone could use another blade for their fan. I hope this helps you!
I have one of these pieces of junk. The motor swarmed, so the rest of the fan is perfect. I'll sell it for $10.00 plus shipping.
Skip [email protected]
