Acer Aspire One  PC Notebook Logo
Posted on Aug 26, 2009
Need a schematic diagram for spark plug wiring showing distributer to plug mechanic removed mine without knowing what went where
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Oct 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
26103
Points
20
There is schematic diagram for your laptop:laptopdesktopschematic.com. there you can read how download laptop schematic free.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Aug 26, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
2410
Points
23
What make and model
Audi q7 valve cover replacement what is minimum I need to remove from the engine and how do I depressurise the fuel rail without a vagcom
Not to worry friend, when my car go sick i avoided going to mechanic looking for DIY_Repair when I found this website https://big-manuals.com/ and this book helped me repair it within an hour, all by myself!!!
From wiring diagrams, schematic illustrations, spark plugs info, parts info, chassis number, valve time settings, step wise instructions, torque specs, error/fault codes, engine info, to every single minute parts, you get everything in there you can't imagine how detailed it is
Free wiring schematics
go to the library they will have a book for your truck that will show you the plug wire location for the distributor and distributor rotation and firing order and cylinder position on the engine. is this is all you need.
Diagram or picture of where the spark plug wires go into the distributer on a engine number 318-1
For this you have to determine when the #1 cylinder is at TDC (Top Dead Center) - when it would be firing. Take the distributor cap off and look at the rotor - it would be pointing at the #1 spark plug wire on the distributor. The wires would be connected it order around the distributor cap starting at 1. The sequence is 1-8-4-3-6-5-7-2 in a clockwise fashion.
1helpful
How do I install a distributer on 1998 vortec engine. old distributer missing
Hi: To Install the Distributor Correctly, 1st thing to do is Remove your #1 Spark Plug assuming it will turn over have someone Turn the Key Off and On in Short Intervals.Either put a Compression Gauge in the #1 Spark Plug HoleOr the Old Fashion Way Works as well just put your Finger in the #1 Plug Hole.As your Helper Cranks the Engine On -Off On -Off.Not A Continuous Crank.When You Feel Air Pressure or See gauge Come up.TYhats when your Engine is a The compression Stroke.Now you Can Drop the New Distributor in its Hole.NOTE: You'll need a Spark Plug and Timing Diagram to See the Position your Distributor ROTOR Line it up to where the Diagram Shows your #1 Spark Plug Wire Will go in the Distributor Cap.If the Distributor Rotor is Not n That Position Your goning to Get Either Back Firing engine May Not Even Stsrt, To This Is Crucial. After The Know that you have The Distributor Droppped The Right position you'll need to Put Gap your Plugs at the Correct Specs, With All Plugs in Now You'll need to Put New Plug Wires on .And They MUST be in the correct order.Sitting inside your Vehicle #1 Plug is the Front Plug on the Drivers Side Next is #3 plug Next is #5 and Your Back Plug is Number 7,On the other side Passenger Front Plug is #2 next #4 Next is #6 and the Back is #8 Assuming you know have your Distributor Dropped in The Proper Position, Put the #1 Spark Plug Wire on the Front Spark Plug (Drivers Side) The Spark Plug Firing Order in Your Engine is 1-8-4-3-6-5-7-2 Clockwise So the Next hole after you have #1 Plug and Wire on And Distributor In Correct Position on COMPRESSION STOKE, Going Clockwise you next wire will be your #8 Position in The Cap And it wil go to the Back Spark Plug on The Rear Spark Plug on Passenger Side. NOTE: Drivers Side Spark Plugs on the Drivers Side Front to Back are Your Odd Numbers 1-3-5-7 Pasenger Side is Your Even Numbers From The Front is #2-4-6-8 Is The Rear PLug .
Heres a Diagram of your Spark plug Positions
Front of Engine
1 2
3 4
5 6
7 8
Hope This Will Get You Going. Let me know The Quality of Help and Solution I've Given You By Voting on It.And May Can Also Send a Testamony
From d_hubbs
1helpful
I need a diagram showing spark plug wires from the distributer to the plugs. i also need a diagram showing where all connections under steer wheel go to
1988 Cadillac Seville 4.5 liter V-8 VIN "5"
For more details about other conections, I suggest visit autozone.com (free register) and review the lot information about your model.
Hope helped with this (remember rated this help) Good luck.
Placement for spark plug wires for 1995 chevy blazer 4wd
i didnt fix it on my own couldnt get the diagram from you your site only gave me a ad for hp printers
i had to take it to a garage to take care of it i dont know if i hit the wrong link let me know
1helpful
Need info on how to change wiring from recirculation to remote
get another electrician, he doesn't know what he is doing, this is not easy to figure out without diagrams of the connector that shows exact wire colors and where they go or went in prev installation..
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
