Frigidaire GLTR1670A Front Load Washer Logo
Posted on Dec 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No spin cycle
During the final spin the machine made a very loud noise and jerked violently. Now you can hear the motor running but it will not spin. The drum can be turned freely by hand. Is this a catastrophic failure?
A
Anonymous
1. If the machine will not rotate by itself, but the motor is running, then it is definitely the belt. Open the back panel with the cord unplugged. It is easy to replace the belt.
2. There is a drain pump accessible from the front bottom panel (2 screws). This pump operates while it is draining. Make sure both the main motor and this pump are operational. If the main motor does not move, then replace the motor.
[email protected]
Anonymous
Level 3:
President:
  • Master 1,294 Answers
  • Posted on Dec 04, 2007
Anonymous
Master
Level 3:
President:
Answers
1294
Questions
Helped
901152
Points
3465
Get the plug off the wall, open up behind & check what it is. Maybe the belt is off...........Only severe cyclones are catastrophic........
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
No spin cycle
Did you check to see if there is a broken
belt present
Whirlpool cabrio (4yr.old) making loud motor straining noise on final spin cycle.
Hi valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address [email protected] with your name, user id (Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
4helpful
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
6helpful
2answers
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
3helpful
FWT449GFS2 making loud banging noises during final spin cycle
lxr6232eqo making loud banging noises during final spin cycle
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
3helpful
Knocking in washer
good luck.........
Rattling noise during spin cycle
2helpful
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
