Garden Logo
Posted on Aug 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Husky pressure washer with a Honda 2600psi engine. Problem is, no water will come from the pressure hose. I connected the water w/out the pressure hose and water flows thru strongly. I then connected the pressure hose w/out the wand and water flowed thru the hose fine. When I connect the wand and pull the trigger, nothing. I have replaced the wand and that was not the problem. Please help.
Anonymous
Level 2:
  • Expert 109 Answers
  • Posted on Aug 23, 2009
Anonymous
Expert
Level 2:
Answers
109
Questions
0
Helped
31195
Points
335
Check the quick disconnect to the wand these are spring operated and can get stuck
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 • Garden
Blockage in pump of huskey 2600psi
You may need to have the pump replaced. Most Husky pumps under 3000 psi don't have parts available. If you bought it within two years, the pump should still be under warranty. Check with Home Depot for service centers near you. They should be able to verify if it qualifies for a free replacement based on the serial number.
Feb 15, 2013 • Garden
1helpful
Husky pressure washer 80432. 1 year old. worked before the winter. no pressure this summer. honda engine runs fine. replaced the pump from the bottom of the engine down... still doesn't pressurize. ...
Check the inlet strainer where the water supply hose is attached,this is located just inside the coupling where you hook up the water hose.
Jul 30, 2010 • Garden
I have a Husky pressure washer w Honda GCV 160. The watwer won't come out the opening the pressure hose attaches to. The inlet is attached to the garden hose but water does not come out the outlet to the...
Not a solution... seems like it is blocked, mine freeflows at least a little water when you turn on the hose (engin off)... Did it get a big slug of dirt from the hose of fawcett? .... puzzzling....
Mar 07, 2010 • Garden
2helpful
3answers
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
21helpful
Absolutely no water pressure on Husky 2600 psi w/ HOnda motor
hook up water hose dose not pump water?
May 26, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
