SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
SOURCE: Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
SOURCE: Service Manual for Xerox WorkCentre m55. URGENT!
Does this link help?
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC_M55&Xlang=en_US&Xcntry=USA
