Mower will not start
SOURCE: I can't post my problem on your web site because you have no category for lawn mower repair!
Look for "new recommendations" in the catagories list
Hope it helps...keep the hope :)
SOURCE: lawn mower won't start
Carb is most likely gummed up and will need cleaning. Anytime a gas motor is store through a season, you should use a product called "stabil" in the gas to prevent gumming up. Also check that there is a strong spark coming from coil. To do this, remove spark plug, hook it up to the coil and set it on motor block and pull it over. You should see a strong spark. If you don't see the spark, then either the coil is faulty or the magnet from coil to flywheel is not getting good contact.
SOURCE: Poulan 6.75 Lawn mower will not start
FOR SURE CHECK ALL PREVIOUSLY MENTIONED ITEMS , TRY THIS...ALMOST GUARANTEE IT WILL RUN............ REMOVE "ALL" OLD FUEL, REFILL WITH FRESH HIGHEST OCTANE FUEL. REPLACE SPARK PLUG (YES, EVEN IF IT LOOKS OK!) GAIN ACCESS TO CARB OPENING, REMOVE AIR FILTER..OR WHATEVER. USING SPRAY CARB CLEANER, FILL ENTIRE CARB AND FLOATBOWL WITH CLEANER....WAIT OVERNIGHT IF POSSIBLE..IT WILL EVAPORATE. NEXT DAY SHOOT MORE INTO CARB..GETTING ANY JETS, ORIFICES ETC..FILL FLOAT BOWL AGAIN. P.S. CLEAN OR REPLACE AIR FILTER IF NEEDED! WAIT A WHILE, GAP NEW SPARK PLUG, INTRODUCE APPROX. 1-2 OZ. OF FRESH GAS INTO PLUG HOLE...QUICKLY RE-INSTALL SPARK PLUG ..WITH ON/OFF SWITCH-BAR OFF..PULL OR CRANK ENGINE A FEW TIMES. MAKE SURE IGNITION CAN FIRE, CRANK(ELECT. START) OR PULL STARTER ROPE & MOWER SHOULD FIRE OVER. IF IT STARTS..RUNS..THEN STALLS (AFTER USING UP GAS IN CARB, TRY IT AGAIN. IF IT CONTINUES TO STALL QUICKLY...YOU WILL NEED AT LEAST A CARBURATOR REBUILD, OR IF NO START AT ALL..YOU NEED TO SEE IF PLUG IS FIRING.
