Hi, your washer water pump, could be burnt out, or clogged up, but first check drain hose for kink, remove back of machine, locate water pump, device that your drain hose are connected to, remove all hoses, pump from washer, and clean, sometimes foreign objects get into it, and prevent pump impeller from spinning, also check water pump winding (coil) with ohm tester, place tester lead, one on each terminal on pump (motor) if you hear beep sound, pump motor o/k, if not, pump burnt out, replace it, but first remove pump, and clean it. after cleaning replace pump, try machine. you could put drain hose, close to floor, into buck, and water will empty by gravity, if water is not emptying, that's evidence your water pump is block, small object (handkerchief, coins etc.) gets into them, from time to time, first clean your water pump, `and check for kink, in drain hoses. . always disconnect power, before attempting any repairs. good luck.
SOURCE: GE front load waher Model #: WSSH300GWW fills and
take drain hose and lay it in a bucket to drain water or a wet vac works better. remove 2 scews from lower pannel it will drop down and come off. look for a accordian shaped black hose. disconnect it and remove junk in it. check inside the pump inlet for stuff it's the thing one end of the funny hose is hooked to. put back together and don't over tighten clamps nut driver tight is fine.
SOURCE: 90 series washer: Leaking, appears to be from the
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
