Lands Phones Logo
Gaelyn Hughes Posted on Aug 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Creating an Outgoing message that tells a caller to leave a messa
I'm missing instructions on how to create an outgoing message when someone rings me (before they leave me a message)
Do you have instructions please
Anonymous
Level 2:
Scholar:
  • Expert 87 Answers
  • Posted on Aug 13, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
87
Questions
0
Helped
33764
Points
302
To Create Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
How do I block a phone number that repeatedly calls me?
As far as I know, you can only do this if your telephone company provides you with the ability to add numbers to a "blacklist". Putting a number on this list prevents the phone from ringing and will not allow the caller to leave a message. The caller will either hear a ringing indication or an outgoing message played to them. You would normally sign into your account of your carriers web site and add the info directly yourself.
I am unaware of any phone itself being able to do this on its own - but they may be out .
Vtech answering machine will not pick up properly
could be outgoing message is set to announce only without an anounce only message being recorded. see http://pdfstream.manualsonline.com/8/8c8ae66b-b461-40cb-b213-039e3c56ab64.pdf page 28
How to configer email address in lotus notes
From what provider are you trying to configure email?If its gmail,
1. Create a Lotus Notes database file to store your POP emails: Lotus Notes does not create a file automatically as Thunderbird or other mail clients do but you have to manually point the mails to flow to a file that is already existing.
2. In the local Address Book, create two accounts for accepting incoming email and sending outgoing email on Gmail. Names are not important but the configuration on the two accounts is!
Account document for Incoming Gmail:
The Basics tab
a. Account name: Can be anything (I chose In Gmail)
b. Account server: pop.gmail.com
c. Login Name: Your gmail email address (complete with the @gmail.com)
d. Password: Your password
e. Protocol: POP
f. SSL: Enabled
g. Only from Location(s): Doesn't matter. Although I would recommend creating a location document specific for Gmail if you are also using Domino Server. I chose creating a location (Gmail).
Protocol Configuration tab: There is only one field here and it doesn't matter what you do with it.
Advanced Tab: This is the most important tab.
a. Port Number: 995
b. Accept SSL site certificates: Yes (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
c. Accept expired SSL certificates: Yes. (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
d. Send SSL certificates when asked (outbound connections only): No.
e. Verify account server name with remote server's certificate: Disabled
f. SSL protocol version: V3.0 with V2.0 handshake
3. Click on Save and Close to save the document and exit. Now you will need to create another account document to handle the outgoing email.
Account document for Outgoing Gmail:
The Basics Tab
a. Account Name: Can be anything. I chose Out Gmail
b. Account server name: smtp.gmail.com
e. Protocol: SMTP
f. SSL: Enabled
a. Port Number: 587 or 465 (Both are SSL port and both work)
4. Once these two documents are created, I would recommend creating a location document to ensure that you separate your gmail from your other Domino based account on the client. The steps to create are:
5. In the same local Address Book, choose New --> Location
Basics Tab:
a. Location Type: Local Area Network
b. Location Name: Can be anything (I chose Gmail)
c. Internet Mail Address: Your gmail email address
Leave the rest as it is.
Servers Tab:
a. Home/Mail server: pop.gmail.com
Ports tab: No changes (ensure TCPIP is checked)
Mail Tab (Most important):
a. Mail file location: Local
b. Mail file: My Gmail.nsf (whatever you created in step 1 above).
Update: A couple of readers pointed out that I had missed an important step in the configuration how-to. So here it is. Step C has been added to include the missed step.
c. Internet domain for Notes addresses when connecting directly to the Internet: gmail.com
d. Send Outgoing mail: directly to Internet
Leave the rest of the fields as it is.
6. There is no need to change the rest of tabs. Click on Save and Close to create the document.
Change to the the new location and you will see Gmail getting downloaded in the mail file you created.
Answering system and fax do not operate together
You want to change a timer on a fax machine to ring more times before it picks up.
Cheers
Machine not answering. new battery. lights on with 0 messages.
When the power went out it may have set the machine to its default setting, "answer function off". Press the "On/Off" button to check for sure. A battery really wouldn't help in this matter because it's only there for backup; when the power goes out the batter will save your settings, outgoing and incoming messages. Perhaps when the power went out you lost your outgoing message, and now, when people call, they don't realize that that they are supposed to leave a message. One more thing you can check is the switch on the side of the phone which tells the machine to answer after 2 or 4 rings.
4helpful
Radio shack 43-3829 answering machine
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS. The switch is on the side of the machine where the cables come out. But here are the instructions from the manual:
Recording Outgoing Messages:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone." You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish. Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
3helpful
How to skip answering machine's outgoing message
When calling someone, press the # key to skip the outgoing message.
Can't make outgoing calls with new SIM card
it might be blcoked by the service provider
2answers
I can not get my phone to pick up on the answering system when a caller is trying to leave a message
Try looking underneath the console of the answering machine. You must turn the answerer on on most machines and underneath there may be a switch to determine how many rings before it picks up as well.
Top NorStar Lands Phones Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
