20 Most Recent
NorStar Flash Voicemail Power Supply Only - Answering Machine Questions & Answers
I am trying to access
Dial Feature 985
When the display changes to say SET something, dial 9
it'll prompt for a password, dial 73738767793
it'll ask if you want to reset the password, say YES
then you'll be able to login with feature 983 1020000
Norstar Flash problem
Cycle the power on the voicemail system. If that does not work, you may have to replace the voicemail power supply, or send the voicemail system for repair.
Good Luck!
Creating an Outgoing message that tells a caller to leave a messa
To Create Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
