20 Most Recent
GE 28111 Cordless Phone Questions & Answers
Blue light flashing.... saying I have new
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
8/19/2014 8:24:07 PM •
GE 28111...
Answered
on Aug 19, 2014
Caller ID Problem on the GE2811 Twin cordless phone system
How to get the caller ID to work on the additional GE DECT phone handsets. You must follow these steps in the exact order :
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes. reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in.
It takes about another 10 minutes after that before all phone handsets start recognizing caller ID.
1/21/2014 4:08:13 PM •
GE 28111...
Answered
on Jan 21, 2014
Phone won't ring
does it say do not disturb? if it does press the red button on the base.... if not then your tring to use it with a voip provider (i.e comcast, Vonage, skype..) this phone wont ring for some reason with out a very specific ring frequency....
8/10/2012 6:06:04 PM •
GE 28111...
Answered
on Aug 10, 2012
I love my GE Model
Your GE phone doesn't have an accessory handset. Unfortunately you cannot replace it with just one handset. If the phone is within warranty, kindly return it to the manufacturer and have it replaced.
9/4/2011 11:38:35 PM •
GE 28111...
Answered
on Sep 04, 2011
My ge model number 28111EE2-A
Press the [do not disturb] button on the base unit.
You can download the manual at
http://www.home-electronics.net/ge/pc/IB/28111EE2_IB.pdf
8/19/2011 7:21:17 PM •
GE 28111...
Answered
on Aug 19, 2011
Model 28111 series dect 6.0 GE phone
I'am subscribed to three way calling from my phone company, but forgot which button to push to connect three way call on my phone is it the green talk button that is in the middle of my phone.
2/17/2010 2:05:48 PM •
GE 28111...
Answered
on Feb 17, 2010
MODEL 28031
THese peice of $hit phones do this to me as well the only thing i could do to resolve it.....was to remove the battery and reinstall it but this doesnt always work a few of my diffrent models from GE do this and im not particularly happy about it... I would recommend not buying products from ge again... because they make the products fail so you will buy new ones (so we cant use the same phone for 10 years)
11/1/2009 10:27:32 PM •
GE 28111...
Answered
on Nov 01, 2009
GE dect 6.0 cordless phone bought at walmart
We had the same problem.
"Our phones worked fine for two weeks but now you can not dial out
and when someone calls us they can't hear we say. The line still works
fine with our old
phone."
To fix the problem, I simply unplugged the base AC plug from the outlet, waited about 15 seconds, and then plugged it back in. Both handsets said searching on the display and then handset names returned to the display as originally programmed. The phones returned to operation as normal.
Devo
2/24/2009 10:07:37 PM •
GE 28111...
Answered
on Feb 24, 2009
Phone works in one jack but not another
Hi, Looks like either the wiring is slightly different or the jack plug not quite with in the tolerance limit. Can you swap the cables between the units (if they are removeable) to eliminate the cable as well. I would suspect the cable on the new phone! I would also make sure there is no dirt on the connectors on the plug...there are minute grooves where you can see the meatl...sometinmes these get blocked!
1/8/2009 9:30:33 AM •
GE 28111...
Answered
on Jan 08, 2009
Do not disturb
there is a red illuminated light on the main base... press it and it will turn DND off :)
11/13/2008 2:06:58 PM •
GE 28111...
Answered
on Nov 13, 2008
Caller ID disappearing
this is a common problem with these overpriced pos phones... i get lines thru all mine and they come and go and lightup for no apparent reason
11/13/2008 12:41:22 PM •
GE 28111...
Answered
on Nov 13, 2008
Says line in use
unplug everythingthen plug it allback in then press the mute button on the phone (program) then go to hand set setup... then go down to de authorize and remove the link..... then reauthorize it
10/10/2008 2:13:46 PM •
GE 28111...
Answered
on Oct 10, 2008
Blue light
Press the mute/program button, then press the caller ID-volume button to select handset setup (then press mute/program again to select this option). Next press tye caller ID-volume until you get to Default settings (its the last setting so pressing the up arrow is the fastest way to it). Press the mute/program button again to select the option. Use the caller ID-volume button to select 1yes. This will return the phone to the factory settings and for took care of the blinking blue light, however you will loose any custom setting or numbers you entered.
The first time I did this it didn't work, so I did again and toward the end of the steps above the phone beeped at me and stated "Reset Default Settings" (or something like that) then time I hit the mute/program button again and everything worked great. I think that last beep maybe have been a are you sure you want to restore to default question.
Remember tis will erase any custome settings you made on the phone (ring tones, ring volume, memory, etc.)
8/27/2008 5:14:01 AM •
GE 28111...
Answered
on Aug 27, 2008
