I forgot my power on password for a compaq nx6110 laptop which I have not used for some time now, how do i reset the password.
Remove the battery and to the power cord.
Remove the two screws that secure the keyboard. After removing the keyboard, remove the battery “RTC” to stop providing energy to epprom BIOS. After the upgrade or downgrade, or any repair, leave the Laptop for 5 minutes, without any source of energy.
Then connect only the power cord without battery and without the battery “RTC” of the Bios.
then turn on the pc without the battery and press f10 change the admin password put the battery of the laptop again not the rtc battery then save changes and exit, reeboot with the win xp disk inside , change boot order and done i garantied it work install xp and then connect the rtc battery done. jajaja easy
You can try to remove the CMOS battery located on the motherboard and re insert again to remove the password..
During the boot up process you will see on the screen press a certain key to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
hope this helps
