Pat
SOURCE: suddenly making a terrible noise when turning the steering wheel.
Actualy it can be front drive shaft,
SOURCE: engine noise
The ticking may have been related to the low dirty oil condition, did you get proof of regular service? the engine in your truck does have some history of oil consumption problems, but I think by 05 they where fixed by Ford, the ticking is either the cam chain or the cam followers, never heard anything called a camshaft phaser, and I have worked for a Ford dealer 20 years. Abnormal oi use is anything over 1 quart US for every 1000 miles of driving, a little more if you drive in hot weather conditions. Put a can of Berrymans Chemtool in the oil, this may help to clean the inside of the engine, also make sure to run either 10-30W or lighter in the engine, heavier oils will cause bearing damage.
SOURCE: Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
SOURCE: lost oil pressure
Highly unlikely that you need a pump, but it is possible that the pick-up tube that extends down into the oil pan, from the pump, has become loose or broken and dropped off it's mount and into the oil pan. It is also possible that the screen on the pick-up tube has become covered in sludge build-up and is no longer allowing oil into the pump. The next course of action would be to remove the oil pan and have a look at the condition of the oil pump pick-up tube and go from there
