20 Most Recent
Bernina BERNETTE 65 Mechanical Sewing Machine Questions & Answers
Wheel goes halfway then gets stuck
If it's a mechanical machine, it could be seizing due to old, dried out oil. How long since it has had a thorough clean and oil? If this is the cause, AVOID running the machine until the problem is addressed or the motor can be damaged.
My Bernina Bernette 65 has a problem with the
try a new needle--one that is for the fabric being sewedthen try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
When I press on the pedal the machine just makes a 'vruuuuuu' sound, and when it sews it tangles around the bobbin! It also does not pick up the bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Damaged needle
8. Warped bobbin
9.First make sure the bobbin-winding spindle (located on top of your machine) has been pushed back to the left for sewing.
10.If it is not in the correct position, the needle will not go down and pick-up your bobbin thread.
11.Next make sure your needle is inserted correctly, with the flat side facing back.
12.Also, make sure your bobbin is in correctly
13.the upper tension disks of your machine are threaded correctly.
14.Make sure the presser foot is up when seating the thread through the upper tension.
15.Turn the handwheel towards you only and hold the needle thread lightly.
16.could be a timing problem
1611
When I press the pedal the string get tangled and I also have problems with the bobbin thread not being picked up! Please help! Thanks margaret
thread the machine correctly( follow the operators manual)
wind the bobbin properly and when placing the bobbin in the bobbin carrier pull the thread down the small slot and under the spring plate
thread for the needle always comes in from the left (The side of the groove in the needle ) and out the cut away side
pull a long piece of thread for the needle out and hold it while you turn the machine over
after 1 or 2 revolutions the needle thread will bring up the bobbin thread and you then pull both threads out a bit
if you don't have a user/operators manual there are 2 options
one is to go google and type in --user manual for bernina bernette model 65 sewing machine and down load the pdf version
the other option is to visit manchester shops ( cloth and fabric shops ) and talk with the sales people as may of these places have a sewing circle of people who will be only to willing to help you.
How to take of covers for maintenace, oiling
I do NOT recommend you take it apart. If you break a "key" it won't go back together. In addition to that, the Berninas tend to have many inner screws that are hard to see. It's difficult to tell if you have a stubborn key, or an inner screw is still tight. It's a great machine, and worth taking it to a professional with the knowledge and correct disassembly sequence. They aren't like old machines that need oiled and greased every month.
