20 Most Recent Bernina Bernette 75 Questions & Answers
3answers
Bernina 730 Can't open top cover !
The problem is that of a stuck piston detent on the pattern selector support that snaps the top cover closed.
  1. Open the light cover
  2. Apply pressure with thumbs on the bottom edge of the top cover on both the right and left sides of the cover. The cover should pop up...Too much pressure on the left side, (if this thing is really stuck) and you might break the top cover at the thread tension slot. Be careful here....
  3. Add a drop of acetone (fingernail polish remover) to the piston detent and work it free by pushing it back and forth. Avoid getting any acetone on the painted surfaces of the machine.
  4. Continue to work free, repeating with a few drops of acetone, and wipe clean. Don't oil this part. It was a petroleum product combined with a galvanic process (aluminum and steel) that caused the problem in the first place, not to mention age.
  5. Use DTE Heavy Medium oil rather than a white or clear oil when you lubricate your machine. White oils are unstable and will oxidize (decay) much more quickly. Also avoid 3 in 1 oil and stuff like WD40....very bad....
  6. Oil 1/2 a drop on those prescribed areas. Too much oil is more harmful than not enough....
  7. Contact your Bernina dealer for this oil.
11/7/2021 4:29:49 AM • Bernina Bernette... • Answered on Nov 07, 2021
2answers
Threading of Bernette overlocker 004D?
You could try to find the manual on eBay
11/9/2020 6:27:16 PM • Bernina Bernette... • Answered on Nov 09, 2020
Where can i get a free bernette 55 manual?
here's a link for a free manual, just click on it to downloadhttp://www.bernina.com/getdoc/4a3fb7af-a8d3-488a-a76a-0147415042a7/Bernette_50_60_70_75_manual
4/5/2018 2:46:42 AM • Bernina Bernette... • Answered on Apr 05, 2018
0answers
Needle holder
do you have a sewing store in your area, I would take it there and ask them to help you. I am sure someone there should do it for free for you. hope it works
10/4/2017 4:08:56 PM • Bernina Bernette... • Answered on Oct 04, 2017
How do I open top part of my sewing machine
The owner's manual should have oiling instructions for the machine. If not, contact a local Bernina dealer. ...
6/22/2016 6:09:24 PM • Bernina Bernette... • Answered on Jun 22, 2016
2answers
Feed teeth have dropped down
Hi. Benieth the free arm there is a lever that you can switch from left to right. This raises and lowers the feeddogs for normal sewing and darning. Possibly you need to flip that switch lever. If that doesn't solve it then the freearm cover on the bottom needs to be removed and the feeddog mechanism cleaned and oiled. Could be stuck.
Good luck. Hope its the easy fix.
Rick
4/24/2016 8:39:26 PM • Bernina Bernette... • Answered on Apr 24, 2016
I have a Bernina Bernette serger 004D/004 and the
The presser foot is a 2 piece thing, remove the foot, then remove the top bit that the foot attaches to (the shank). Look at the bottom of the shank while pressing the little lever or button on the back of it, you will see how the foot attaches to the shank.
4/21/2016 1:35:04 AM • Bernina Bernette... • Answered on Apr 21, 2016
2answers
Where can I get power cord, foot pedal, and manual?
About 17,700 results (0.94 seconds) Search Results
    Bernette Sewing Machines - BERNINA Support: Machine ...
    www.bernina.com/...Manuals/bernette-manuals/Bernette-Sewing-Machin...
    Bernette Sewing Machines Within this section are the Bernette series of sewing machine manuals that are no longer ... bernette 50 / 60 / 70 / 75 Manual (7.4 MB).Missing: power
    [PDF]Manual - Bernina
    www.bernina.com/de/.../BERNINA.../bernette.../Manuals/deco340_EN_...
    Congratulations on your decision to buy the bernette Deco 340. By owning .... Insert the power supply plug into the wall outlet and turn the power switch on. 1.
    BERNINA Support: Machine and Accessories Finders, and ...
    www.bernina.com/en-US/Support-US
    Out of Print Manuals. Out of ... BERNINA FAQ - Find answers to frequently asked questions. ... Please note: this service can only address SOFTWARE questions.
    www.bernina.com/.../BERNINA.../BERNINA.../Manuals/0333017104_2...
    You've decided on BERNINA, a reliable choice that will delight you for years to come. For over 100 .... Power cable. ยท .... control the sewing speed by pressing the foot
2/4/2016 1:14:24 AM • Bernina Bernette... • Answered on Feb 04, 2016
2answers
Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
5/20/2015 4:32:49 PM • Bernina Bernette... • Answered on May 20, 2015
2answers
I have a Bernina 2000D and it will not sew
If you visit this company:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Bernina.htm
Sadly you will have to pay for an instruction manual, leads to a PayPal account.
Please rate this thanks,
4/3/2015 3:44:27 AM • Bernina Bernette... • Answered on Apr 03, 2015
I recently got an older bernette 334 ds serger and it doesnt look like it hss ever been used. i went to plug it in and run it and nothing happened only light came on
If it's old and has never been run, it will need a proper service fro the parts that have become immobile due to the lubricant "gumming up". Off to the sewing machine shop for you!
3/3/2015 10:08:33 PM • Bernina Bernette... • Answered on Mar 03, 2015
Please could you tell me the age of the Bernina 1020 and the 1020
Find the serial number, engraved into the metal on the back of the machine or low down on the hand wheel end. First digit is the decade: 1=1970's, 2=1980's, 3=1990's Second digit is the year in the decade. E.g. my 1030 is 27230888 so it was made in 1987.
2/3/2015 10:29:54 PM • Bernina Bernette... • Answered on Feb 03, 2015
I lost the extension table to my bernette 75 sewing machine, Where can I replace it?
THERE ARE MANY AVAILABLE SO YOU CAN ORDER A GENERIC ONE OR ONE THAT IS ESPECIALLY MADE FOR YOUR MACHINE. YOU CAN ALSO LOOK ON EBAY AND FIND THIS TYPE OF EQUIPMENT. http://www.sewingpartsonline.com/
1/2/2015 10:21:04 PM • Bernina Bernette... • Answered on Jan 02, 2015
Needle sticks
Bent needle and dirty machine or machine in need of a proper COA (tuneup) are my first thoughts.
5/24/2014 5:45:30 PM • Bernina Bernette... • Answered on May 24, 2014
Sewing Machines Logo
168 questions posted
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bernina Sewing Machines
Most Popular Question
get free bernette 55 manual
  • Sewing Machines
