Jack Bitting Posted on Jun 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio Sirius Sat AM FM intermitin plays for 2 seconds off for 4seconds &repeat
Dennis
Level 3:
Top Expert:
  • Master 1,057 Answers
  • Posted on Jun 08, 2019
Dennis
Master
Level 3:
Top Expert:
Answers
1057
Questions
Helped
441191
Points
13558
Method to troubleshoot Sirus intermittent connection.
https://www.vaistech.com/satellite-radio-cutting-out/
5 Related Answers
Anonymous
  • 640 Answers
  • Posted on Oct 23, 2007
SOURCE: Ford Explorer Sirius radio
sometimes if you dont put the right code in all the functions wont work.factory radios nowadays go thru the ecm (electronic control module) of the veichle.meaning if your radio was stolen and put into another vehichle it would be locked,and a code needs to be put in.unplug the battery and radio and go to this site to find your code.http://gsmhosting.com/vbb/showthread.php?t=350260
A
Anonymous
  • Posted on Jun 19, 2008
SOURCE: connect sirius fm adapter to 2008 honda civic sedan radio
Yes. Factory installed radio.
A
Anonymous
  • Posted on Jul 10, 2008
SOURCE: Panasonic CQ-DF903U How do I hook up my Sirius Radio to it?
Sirius radio connects via a special dock. Sorry, but you're screwed with your XM unit...
A
Anonymous
  • Posted on Aug 06, 2008
SOURCE: Clarion & Sirius Radio reception
Did You pay Sirius for their service?
Anonymous
  • Posted on Mar 13, 2009
SOURCE: sirius satellite radio
You will need to get another sat antenna, and locate it somewhere either above the camper, or where the camper does not obstruct the antenna. Any store that sells sat radio equipment (Fry's, Best Buy, etc) will have the micro antenna. Install it either on the hood of the truck, or on top of the camper. You will need to run the antenna to the rear of the dash. They make Y couplers that will allow you to run both the OEM antenna and the extermal antenna at the same time, and it will not hurt the system to have both wired in at the same time.
Have a 2007 Jeep Commander. Sirius is intermittent and will flip over to FM frequently
First question is if you ever spilled a soft drink into the radio such that the AM/FM/SAT switch gets sticky?
2nd, do you have any way to pull-out the radio and borrow a magnetic-mount Sirius antenna to temporarily test and see if the antenna on the vehicle is bad?
If passing the first two tests, then it's likely the whole radio unit has to be replaced with a model from a similar year. Actually, the audio quality you get from an XM Onyx will be much better than the Sirius radio in the Chrysler vehicles, and you can just use the AUX input on the radio for playback.
Sony CDX-GT320 FM / AM / XM Radio / Sirius Receiver missing sat option?
Check the connections between the head unit and the XM tuner. If the connections are good check for power and ground.
What fm station do i use in the car
You need to find a clear radio frequency in your area then in the SIRIUS sat radio you will find a FM transmitter frequency adjustment menu. set it to the same as your fm radio and your all set.
Sirius Radio
did you get anthing on this.. If so, please email me at [email protected] I have the same problem.
1995 Jeep Cherokee Radio replacement
Most of the New Aftermarket Stereo's now have the Connections for Sirius and XM Built in so you just need the Sat. Install Box. Really Simple. If you want to go a Cheaper Route Just Purchase the XM or Sirius Reciever and Mounting kit for the Dash or Windshield and It will play through an Empty FM Station on the Radio Via the FM Transmitter. Got one in all of my Vehicles and they work Great!
1helpful
Sirius S-50 Portable
Go to device settings - FM Frequencies - select the FM 1 or FM 2 or FM 3, turn the dial to move the FM frequency to that which you want. Press the Sirius Dog to enter this frequency. That's it.
1helpful
2answers
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Static sound
Some Pioneer radios allow for seperate audio controlls between FM CD and External sources like you Sat Radio. It may be that your settings are out of wack (Prob the factory setting which is crap), try that out and let me know.
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
