SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
SOURCE: BROKEN STOVE KNOB
try web site www.firstsourcesupply.com they should have the parts as long as you have ser# and model# they can ship to you. Good Luck
Dave
SOURCE: i have a ge xl44 gas range. the oven knob has come off
You will need to locate your full model #, usually open the bottom drawer and you can see it on the chassis on the right or left side. Try searspartsdirect.com type your model in and it will give you a parts breakdown and about the best assembly view your going to get. Sometimes there is more to be desired but this should help. Please rate this post.
SOURCE: Control knob replacement for Kitchen Aid Range
If you have this information already (KitchenAid KESC307) then that is all thats needed to order the stove knob. If that isnt the number, try opening the head of the stove and look for the manual there, or it may be taped to the back or underside of the broiler area. Also try looking under the burners for an aluminum serial number plate. The original plate will be stamped as well as printed, so if you only found the printed one, there should be another stamped plate elsewhere.
SOURCE: I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
