20 Most Recent GE JGBP33 Gas Kitchen Range Questions & Answers
Ge oven will not heat up
If it sets the temp and all other functions work then it's probable you need to replace the thermometer, usually something has banged into the small copper tubing causing a crimp or a crack, it's not a big job and in most cases you can pick up a replacements from a local service shop relatively cheap. Not a difficult job and usually instructions are included.
4/6/2014 1:43:35 AM • GE JGBP33 Gas... • Answered on Apr 06, 2014
0answers
0answers
GE gas range JGBP33WEH3WW totally dead after self clean
There may be an oven over temp thermal switch that has opened and needs to be replaced. Also you need to determine why the temp got so hot to cause this safety device to do its job. This might be a failed cooling fan
11/20/2013 12:24:56 AM • GE JGBP33 Gas... • Answered on Nov 20, 2013
The electre polit light system does not work turn
You will need to replace spark module. Here is the part to order.There is alsoa video on that same page to show you how to make the repair.
10/20/2013 5:01:55 PM • GE JGBP33 Gas... • Answered on Oct 20, 2013
0answers
Electric oven stopped working after
You most like have a bad oven control. But make sure that your outlet is woeking properly.
6/17/2011 6:45:45 AM • GE JGBP33 Gas... • Answered on Jun 17, 2011
I have a GE JGBP33CEH4CC
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
1/16/2011 6:18:53 PM • GE JGBP33 Gas... • Answered on Jan 16, 2011
Stove top works but not
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
11/27/2010 2:02:35 AM • GE JGBP33 Gas... • Answered on Nov 27, 2010
I have a GE TrueTemp oven/range - oven is not working
I had a similar problem.The power failure might just have been a coincidence.Sounds to me like your lower oven igniter may have gone bad such as mine did.
9/11/2010 4:52:15 AM • GE JGBP33 Gas... • Answered on Sep 11, 2010
The oven does not turn on. however, the stove top
You may have a bad igniter on the oven manifold. The broiler and oven use separate igniters. So, if the broiler works, you don't have a gas problem. No ignition is most commonly attributed to an oven igniter that is going bad. As these igniters age, they become weak and require replacement. The following link explains some theory behind how they work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
Replacements parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary, so shop and compare.
NOTE: If the replacement igniter comes with a connector plug that does not match the one on your range, you will be instructed to cut the old connector plug off and splice the wires together using a set of ceramic wire lugs that are included in the replacement kit. DO NOT attempt to use standard wires lugs. They will melt due to the extreme heat in an oven. The ceramic lugs and the wires on the igniter are heat resistant.
NOTE: If BOTH oven features do not work, these features are controlled by the Electronic Oven Control (EOC) board. This is the clock/timer assembly on the operator console. It is possible for the control board to fail and disable both oven features. If you have any questions about this repair, please let me know. I hope this helps you.
12/23/2009 2:16:41 AM • GE JGBP33 Gas... • Answered on Dec 23, 2009
2answers
I own a GE JGBP33BEH5BB and the oven doesn't get
The orange glow is the igniter. Normally, the igniter turns on and begins to glow. As the igniter heats, the change in it's resistance causes it to use more electrical current (amperage). When the amperage level reaches a threshold (let's say 3.2 amps, for an example) the ovens safety gas valve will open because in knows the igniter (using that much electrical current) is hot enough to light the gas. This process usually takes under two minutes. The igniter stays on until the oven reaches the set temp, then it turns off, and the gas valve shuts off very soon after. Then the cycle repeats when the oven thermostat call for heat again after cooling down a bit.
The trouble is, as these igniters get old, they have a harder time reaching that needed amperage threshold to operate properly. You can just swap the broiler igniter with the bake igniter if you wish, as they are the same part number in your model, and the broil is generally used much less, and so should have much more life left. (of course now the broiler and the self clean will not work, until you replace the broiler igniter with a new one.) In rare cases, if you have low line voltage to the range (say 108 volts) that will also cause the same problem, or if you have a poor electrical connection, but those cases are rare, and about 99 percent of the time your problem will be fixed by replacing the oven igniter. (GE part number WB2X9154 for your model)
Sorry to get so long winded. Just replace the oven igniter.
8/16/2009 3:45:14 PM • GE JGBP33 Gas... • Answered on Aug 16, 2009
Broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Thanks
Vic
7/17/2009 6:19:12 PM • GE JGBP33 Gas... • Answered on Jul 17, 2009
GE JGBP33 Gas Kitchen Range Logo
40 questions posted
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
GE Kitchen Ranges
  • GE Kitchen Ranges
Most Popular Question
ge jgbp33ceh4cc
  • Kitchen Ranges
