If not able to get dvd player and use options
Checking this model on the Sony site states that several apps no longer will work after 2015 onwards. If the TV is good what I did was to upgrade it by buying a smart box such as. An android TV box and costing about 50 dollars much cheaper than buying a new smart TV.
Hope this was useful.
Hello
you cannot upgrade this set because you tube change her security para meters and cant upload in this set so this set is not compatible or YouTube.
thanks
M Nasir
SOURCE: DVD Freezing / skipping
It almost has to be the discs. Try them in a friends unit.
I had a similar problem with DVD's I burned and had printed labels and put the label on the discs. It caused the disc to be out of balance. I peeled them all off (what a job) and the discs play fine now. I'm now a "magic marker" person... :)
Geno
SOURCE: Sony Bravia KDL-46Z4500 Captions
Try pressing the 'Display' button on top left of TV remote.
SOURCE: my onida dvd player cannot play mkv & rmvb
if it has no capability to play such files then there is no way to upgrade it.
SOURCE: sony bravia kdl- 4052510 picture but no sound from
1 Press volume +/- or Mute 2 If it does not work then check if the 'speaker' is set to 'TV speaker' from the "AV set up" menu in "Settings" 3 Press Menu and select Settings. Go up/down and select Set Up icon.Press enter 4 In AV Set up go to speaker and turn on the TV Speaker. This should solve your problem
