20 Most Recent
Sony Bravia Z KDL40Z4100 TV Questions & Answers
I have several horizontal lines
If you get this result from multiple inputs (IE HDMI, composite etc) it is likely a defect/failure in the screen. This is not something you will likely be able to fix yourself.
I recommend contacting Sony on how to proceed on getting it fixed. If it is still under warranty they will likely send a tech to look at it or may even send you a replacement.
Below is the number and hours of operation for Sony TV Support line.
Priority Service: 239-768-7547
Hours:
- Mon-Fri 8:00am-12:00am (Midnight) ET
- Sat-Sun 9:00am-8:00pm ET
Sony KDL-40WL140 vs KDL-40Z4100
KDL40Z4100
Product Features
- 16:9 Full HD 1080p Resolution (1920x1080p) LCD Panel
- Motionflow 120Hz; improves TV & DVD viewing
- DMeX compatible; allows seamless feature upgrades
- DLNA® Compliant - view photos from another room
- HDMI x4, HD Component x2, PC Input
Technical Details
- Brand Name: Sony
- Model: KDL-40Z4100/B
- Display Technology: TFT active matrix
- Display Size: 40 inches
- Image Aspect Ratio: 16:9
- is_hdtv_compatible: Y
- speakers_included_description: 2 speakers
- Height: 23.9 inches
- Width: 37.2 inches
- Depth: 2.8 inches
- Weight: 39.7 pounds
- Refresh Rate: 120
KDL-40WL140
Product Features
- Motionflow™ 120Hz - clear, smooth motion for DVDs, TV
- DMex ™ compatible; allows seamless feature upgrades
- Enhanced XMB™ with 3D graphics incl. TV Guide
- HDMI™ x4, HD Component x2, PC Input
Technical Details
- Brand Name: Sony
- Model: KDL-40W4100
- Height: 25.4 inches
- Width: 38.8 inches
- Depth: 4.3 inches
- Weight: 44.1 pounds
- Refresh Rate: 120
Bottom line for the extra connectivity and DLNA certification i would go with the
Bravia Z-Series KDL-40Z4100/B 40-Inch 1080pBecause if you connect this to your in home network you can stream music videos and music off you PC onto your TV without the need for extra wired or memory cards etc.
Otherwise if you don't need this feature the other options are identical on the other TV so it is just as good a choice.
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it.
I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
How can I watch Netflix on a tv Sony wega that isn’t hooked to the internet. It’s wirelessly connected to Vizio ( smart tv Netflix built in) but I want to be able to watch in a different room
netflix is a 100% internet web site , streaming site.
thus the net in flix.
what did you mean by hooked?\
do you have internet at home at all?
do other things in home work to the internet, like PC or cell phones.
what I can not under stand is (different room) this phase
implies some rooms do work (netflex)
and wifi gets weak if my move any TV farther from the home router
and will fail past 25 feet or more. wifi is super weak through walls
for sure brick, or 2 walls.
if home is small one wifi access point is all you need
if huge home more.
distance matter, TV to router.
no TV model # told. (tells me wifi spec)
if you said my TV works in room 1 but not room 2, wifi;.
it be super more easy to answer.. is this true?
if true , get a tech to upgrade your wifi.
or go wired, Ethernet.(a better home upgrade)
No sound some channels
HI
IN THIS CASE YOU LED TV CHANG AUDIO FORMATE PLEASE GO TO TUNING SECTION THEN IN FINE TUNING AND THERE IS SOUND OPTIOND LIKE BG DK I AND M SELECT ONE ACCORDING TO YOUR COUNTRY
THANKS
M NASIR
