20 Most Recent
Logitech Harmony 880 LCD Remote Control Questions & Answers
Lost manual for model # 880 need to
You can get an online copy of the user manual. There are two models in this category, 880 and 880 pro.
For 880 click
here.
For 880 pro click
here.
The above manuals are in pdf. You need to have the free Adobe reader installed.
The remote continues displaying a low battery
your remote charges in a base, is the tv very old or new, if its under warranty check where you bought it, if its not, see if you can replace the batteries in the remote, they will get old and malfunction, they are probably small batteries like go in a heraring aid or computer, if there are several, one can go bad causing the others to go bad, clean the terminals on the pad and remote, use a pencil eraser, to clean them, sometimes they spill coke or just your hand can contaminate the conections.Matt
Buttons not responding
1) change the batterie with the same type and fully charged2) clean the contacts battery with c.cleaners3) retight the spring contacts battery with pliers, for a good contacts.v.iMPORTANTE4) PROOF 5) if doesnot resolve the problem6) open the r. control and clean the keypads swithc, for dust,etc, open contacts, or band contacs.7) otherwise you must go to the repair shop TVGod bless you
Harmony 880 buttons not responding. Screen message says
1) change the batteries with the same type and fully charged2) clean the contacts with contacts cleaner3) retight the springs contacts with pliers for GOOD contacts.very important.4) Proof5) if this does not resolve the problem6) open the remote control, and clean the keypads swithc. very well with contacts cleaners
Harmony 880 universal remote re-charging problem
I took the rubber feet off(4) from the underside of the cradle - removed the four screws and separated the top half of the cradle from the bottom. This exposes the two long thin charging arms and points All one piece). I then took some doubled sided tape, similar to what you use to put up temporary 3m picture hooks and cut four small pieces about 1/8th in square. Join two of the pieces back to back to make one piece (double original thickness), then raise one of the long charging arms gently and place the piece of double sided tape under the head of the arm (ie under the very end where the rounded point is, that sticks though the cradle when reassembled (there are two of these). Do this to the other arm.
Why - by inserting the doublesided tape you permanently raise the arms without bending them - ie they will now stay in that position and not bend out of shape, losing contact again . With the cradle reassembled, put the remote back in the cradle you will have more direct contact with the two charging pins. FIXED!!!!!!!! Good luck1
Setting up my Harmony 880 to work with My Sharp Aqous TV and LG 3400 DVD player - I gt no picture or sound
Begin the Setup ProcessStep 1: Create your Harmony LoginIf the Harmony remote web site is not automatically launched, go to the Harmony remote web site andcreate an account.Step 2: Complete the Online Setup ProcessOnce you have created your Harmony login, the online setup process begins. You will guided through aseries of question-and-answer steps to complete each of the five main steps of the online setup process:1. Identification: Requires you to create a login on our member web site.2. Check Connection: Ensures your computer and your Harmony remote are communicatingproperly.3. Set up Devices: Helps you set up a description of your personal home theater system.4. Set up Activities: Helps you set up a description of the connections for devices that allow you toperform Activities (e.g. Watch Television Activity).5. Update Remote: Updates your remote with your personal configuration.
Logitech software
Consult the owner manual--some if batteries removed for a few minutes all programmed units will be deleted but if that you will need to program other units back later.I would suggest if you do not have the manual to google the model number of the set or remote to try to locate one online for free.SD TECH
Logitech Harmony 880 remote control repair for
Hi. Unfortunately Logitech does not provide repair service for any
products, so unless you are good at electronics and soldering this might
not be an easy thing to fix. When my old Harmony 550 has button issues,
I called Logitech about it and they gave me 50% off to upgrade the
remote. This could be a good option for you.
Regards,
D
Lost installation cd-rom
Hi. You don't need the CD to install the Harmony software. It can be downloaded at http://logitech.com/myharmony.
Regards,
D
My volume up on the
If the buttons used to work then yeah it sounds like a hardware issue. You can go ahead and take the remote apart, but I don't think you will be able to fix it, unless you are good at soldering. Cleaning the contacts alone won't help. This same thing happened to the most used buttons on my Harmony One, and I just assigned the commands to the screen, so I could continue using the remote without those buttons.
If you want to try assigning the buttons to the screen, the steps in this article by Logitech will help:
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9766/kw/buttons
I hope this helps.
I bought a new battery
Hi, this is a common issue with the Harmony 800 series. What I do, is use an elastic band to keep the remote firmly in place on the charger, so that it does not lose contact.
Hope it helps.
The backlight for the buttons
Try updating the firmware on the remote, as this solved most issues. To do this, log in to the software, click "Downloads" at the top of the screen then click "Firmware." Follow the on screen instructions to update your remote's firmware and configuration.
Logitech Harmony 300 all 4 Device butons flash at
Oh wow! Either delete all 4 devices online and reprogram it making sure to hit the "sync" function or whatever function is provided to complete the process online, or take it back to your dealer for clarification or refund.
