Every pc/laptop will only accept a certain amount of memory. Your probably overloading it. Check in your system info to see how much it can take. Also, make absolutely sure that you have the right memory stick for you pc!
Denon receiver has a common problem, keep shuting down after power button press, then red light blind. mostly, if none of amplifier output transistors blown, it must be IC7815 or IC7915 mulfunction, find it, replace it. then job down
You should have an error code legend in your owner's manual. Check to see what "OE" relates to on the washer. If not in your manual, you should be able to determine what the code relates to via LG's website. You may need to contact an appliance service company.
This could be caused by MANY different things. If it is a random thing, where do you have your laptop when it happens? If it isn't on a flat smooth surface, it's probably a heat related issue. Laptops need a lot of air circulaton, through the bottom.
If the receiver shuts down after some time operating properly it is likely caused by a heat issue or crossed (shorted) speaker wires. Please make sure that the unit is adequately vented and the air vents/fan on the back of the receiver is clean. If it is then carefully check all of the speaker wires for cracks, damage, and/or crossed wires.
