The speed function does not work. Will only operate very slowly.
SOURCE: JANOME dIGITIZER 10000 - "JANOME.EXE has stopped working"
Digitizer 10000 v2.21 might run in compatibility mode on Vista, but there's no gaurantees. Even the latest digitising suite Digitiser Pro/MB is experiencing problems running in Vista 32 and as yet has no real fix (driver) for Vista 64.
SOURCE: I had lost my manual and need to fix some problems.
Not sure if this will help, but try---
www.2instructions.com
SOURCE: how do i make the needle stop in the down position
You can't - it is only designed to always stop in the up position, then you can manually push the "needle down" button to make the needle go down while you turn a corner. The next model up the 4263 had the "stop down" option. Sorry.
