Likely there's a size limit to the USB memory stick. It doesn't say in the 200E manual but a search on "usb stick" on the Janome site would indicate some earlier USB capable machines may have a 2GB limit.
Thank you very much
This machine can update version?
There is a v1.03 update, but I don't know what's in the update... and you likely have the memory problem as the update method uses USB.https://www.janome.com/siteassets/suppor...
Suggest you can contact Janome directly via email. see following link for country email addresses.https://www.janome.co.jp/e/e_links/ameri...
SOURCE: I am having trouble transferring designs from USB
Ok, you need to put the file in the EMBF folder on the USB stick and the the machine should be able to see it.
SOURCE: my janome 200e is showing the bobbin on top of the monogram. How can i fix it?
Fill your bobbin.
