Electrical Supplies Logo
A
Aaron Posted on May 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Biesse skipper V31 manual - Electrical Supplies
Terry
Level 3:
  • Master 11,377 Answers
  • Posted on May 04, 2019
Terry
Master
Level 3:
Answers
11377
Questions
Helped
4626975
Points
152765
How to adjust bobbin thread an what presser foot should I use for straight stitch?
Page 61 of the manual says to check whether the bobbin is threaded properly as well as adjusting the upper thread tension with a wheel.
https://www.manualslib.com/manual/250257/Brother-885-V31.html?page=61#manual
as to which presser foot, #4 on this diagram looks likely, though I've also used the zigzag foot (#5) for flexibility in case I need to anchor something with a zigzag or such.
https://www.manualslib.com/manual/250257/Brother-885-V31.html?page=10#manual
Will an embroidery unit for a brother v31 fit an se400?
You may need a shank adapter. Most dealers have them available.
T8845pv Timer ignores pin up for no water day
I think this is how it should operate:
When the day skipper pin is pushed down on skipper-wheel....
... the day skipper pin pushes a lever away from trippers... so the trippers will not engage the lever ... and the day of watering is skipped.
Turn power OFF.
Take off plastic cover over the wiring terminals.
See if that is how it works, and look to see if something is missing.
Here is close up based on Intermatic image of 14-day skipper wheel, and you can see (what I assume) is the skipper pin pushing a lever.
http://waterheatertimer.org/images/Sprinkler-day-skipper.jpg
Attach close-up photo of your timer.
If you have digital camera, set to macro or tulip icon for close ups... otherwise phone cameras don't give clear view unless lighting is good.
Assuming the timer is defective... I am not certain of Intermatic's warranty policy... except they have 1 year full warranty, and could send just the timer mechanism so you do not have to replace the box... steps: take photo of wiring, disconnect wires, snap or screw new timer into existing box, reconnect wires, and then send defect back to Intermatic.com.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
1helpful
There is a silver pin that fits into the periphery of the timer. I think this trips the smaller dial to rotate. If the sprinkler is set to go off at 4am, where should I place this silver pin for it to...
You have Intermatic sprinkler timer.
The silver pin inserts into the yellow dial at 12:00 midnight, and it rotates the skipper wheel.
Skipper wheel is necessary only if you want to skip certain days of the week, otherwise the timer cycle repeats each 24-hour period.
To skip a day, the skipper pin is pushed down for that day. Leave skipper pin up for days you want to water.
Open following links for more information:
2helpful
2answers
How do you progran the day of the weeks it should water the lawn
Turn black skipper wheel COUNTER-CLOCKWISE until todays day is in front of "14" arrow. Press pins DOWN on days of NO watering. The skipper wheel must have all pins UP for daily watering
I hope that shud solve the problem, taken directly from the manual
1helpful
How do you set the days that you want the system to operate ?
R88 series timers at Intermatic.
Click on model number to see manual:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Add a comment if you have different timer
At fixya, we're not supposed to copy-paste from manual, but manual says information clearly.
If timer has the day-skipper wheel located lower left of large yellow dial:
Not every timer has day-skipper wheel, in which case timer works same for each day.
TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
until today's day is in front of "14" arrow. Press pins DOWN on days
watering.
Additional instructions:
1. TO SET FIRST ZONE: For watering, push gold pin into slot on yellow
dial at desired ON time. For each 12 minutes of additional watering
add one pin WITHOUT skipping a slot.
2. TO CHANGE ZONES: Leave one blank slot on yellow dial after ON
line (gold pin), and valve will automatically advance to next zone.
3. TO SET ADDITIONAL ZONES: Repeat steps 1 and 2. REMEMBER
to leave blank space between zones
4. TO SET TIME OF DAY: Turn yellow dial CLOCKWISE, until correct
line is at end of silver time pointer. Do NOT turn silver pointer.
5. TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
watering.
6. PUT SELECTOR SWITCH IN AUTO: This switch can be used to turn
the system ON or OFF for manual operation without affecting the set
program.
HOW DO I SET TODAY MONDAY, SO THE PUMP WILL START ON WEDNESDAY? I PUT MONDAY IN FRONT OF 14 ARROW AND PULL THE PIN OUT FOR WEDNESDAY BUT AS ALL PINS PASS ON YELLOW DIAL TO GET TO WEDNESDAY AND THE 12 MIN....
http://waterheatertimer.org/images/R8806P101C-timer-778.jpg
1) The silver pin goes at 12 midnight on large yellow dial. This pin advances the skipper wheel each day.
2) Turn yellow dial clockwise until current time lines up with silver pointer.
3) Rotate skipper wheel counter-clockwise until today's day (Monday) is in front of 14 arrow.
4) To skip a day of watering, the skipper pin is pushed down for that day. So you want to push down Monday and Tuesday.
For watering, the skipper pins is up for that day. So you want The skipper pin up for Tuesday.
5) The brass trippers are inserted on yellow wheel. Each brass tripper represents 12 minutes of watering for example. So if you want to water for 1/2 hour, then put two consecutive pins on the yellow timer wheel. For 1 hour, put 4 consecutive pins.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
