SOURCE: Panasonic CQ-DF903U How do I hook up my Sirius Radio to it?
Sirius radio connects via a special dock. Sorry, but you're screwed with your XM unit...
SOURCE: Factory XM Unit Location
Hi Xit.....The factory XM module is in fact located under the rear shelf trim panel. You will have to remove the rear seat cushion, just pull up on the front of the cushion about 12 inches in from left and right corners. Remove the cushion from the car. Open the trunk and remove nuts located on the seat back just under rear shelf metal. Back inside the rear seat area, remove the seat belt buckle bolts located inboard of right and left lower corners of the seat back. Remove the seat back. You will now be able to see the (2) plastic fir tree pins that hold the shelf panel trim in place. Remove the pins.
Now comes the hard part, remove the right and left quarter sail interior trim panels ( Caution: roof rail air bag located behind right and left panels) the fasteners are located behind the "SIR" plastic buttons in the sail panel trim.
All in all, unless you have the proper tools and take the proper precautions, you might want to take your Cadillac to your local dealer.
Buy the way, is there something wrong with your factory XM module?
Let me know, regards.
SOURCE: xm radio
We had the same problem with our 2007 sonata, it is actually hapening again now. We took it to the dealer the fist time and they had to repace the xm unit (under car somewhere) apparently when it rains really hard the unit gets wet. I guess we have to take ours back again, it started acting up again after a recent rain.
SOURCE: No Signal on XM Radio - Goes in and out of Signal
xm will not hold signal but if I move the antenna wire around inside the vehicle it will suddenly come in clear as day
SOURCE: XM Radio in 2008 Hyundai Sonata sounds bad
Same problem here. I repeatedly complained to XM but got no reply. I listen to XM in 2009 Sonata and it was just as bad.
XM is better than AM. Much worse than FM.
