20 Most Recent Panasonic CQ-DF903U CD Player Questions & Answers
2answers
Panasonic CQ-DF903U How do I hook up my Sirius Radio to it?
Sirius radio connects via a special dock. Sorry, but you're screwed with your XM unit...
9/3/2011 10:53:52 PM • Panasonic... • Answered on Sep 03, 2011
I have no manual and
No problem? Your manual is here. Good luck with it. http://a248.e.akamai.net/pix.crutchfield.com/Manuals/133/133DF903.PDF
4/1/2011 10:12:10 AM • Panasonic... • Answered on Apr 01, 2011
How come my panasonic CQ-DF903U
you probably burned your cds in mp3 format. you need to burn them in wmv format.
2/28/2011 6:49:27 PM • Panasonic... • Answered on Feb 28, 2011
How to program the presets for radio
hi, it sould be easy, i have never do this one before, but, normally. you need to find SEARCH UP or DOWN.
you may have 6 or 10 preset staions this due to 6 CD or 10 CD
PRESS SEARCH UP find the station you want KEEP PRESSING No 1 POSITION, you should hear a BEEP or the No. 1 station will FLASH, and let GO of the BUTTON, this STATION IS SET.
the next station PRESS SEARCH UP find station KEEP PRESSING No. 2 a beep should be heard or flash station No2 is set and let GO of the BUTTON. this STATION IS SET,
that is the basics and the same for all the stations
9/11/2010 7:18:25 AM • Panasonic... • Answered on Sep 11, 2010
My cd player in my car won't play cd's now. When
Hello there:
this means that it cant read the cd rom , because of the following conditions the cd rom is scratched or dirty or that the lens on the player is dirty and is in need of cleaning or that the player has failed all together
ok so try to clean the player with compressed air and a cd cleaner with some cleaner on it first than make sure that the cd rom is cleaned and not scratched and if still nothing is working you might want to consider a new player ok? Hope that this is very helpfull
best regards michael
10/23/2009 2:55:32 AM • Panasonic... • Answered on Oct 23, 2009
NO Sound At All
Checa con una bocina externa las salidas de audio del aparato,si funciona las bocinas del carro son amplificadas.Y si no funciona el amplificador de audio del estereo esta quemado.
1/13/2009 1:25:45 AM • Panasonic... • Answered on Jan 13, 2009
My friend gave my his
You need a Sirus reciever, Antenna, and Subscription to the service.
1/8/2009 2:22:27 AM • Panasonic... • Answered on Jan 08, 2009
Wont play cd
Is this a "home burnt" CD? The code means CD ERROR #2.It is usually because the CD was written in a format the head unit can not play.If it is a studio CD. I would contact Panasonic and find out what code # 2 means.I had a code too because of what I said before but I do not remeber the # it was.
6/19/2008 12:25:08 AM • Panasonic... • Answered on Jun 19, 2008
Cqdf903u powering on but no sound in 2001 vw jetta
Puede que las bocinas sean amplificadas si es asi tienes que buscar un cable que trae el sistema del automovil para que funcionen si son las originales del carro
3/29/2008 4:21:13 PM • Panasonic... • Answered on Mar 29, 2008
When you unhooked your deck it still had power going to it, you need to unplug your car battery and plug it back in that should reset the deck and get the error message to go away.
Good luck,
Chris
2/27/2008 3:40:39 AM • Panasonic... • Answered on Feb 27, 2008
How to install a panasoinc cq-df903u in 91 integra
The wires for the two harnesses should be color coordinated or at least closely colored. The harness should have come with either a guide that says what is what or the wires themselves have little flags saying what they are. You can use this to match it up with CD Players wires by using the manual from the CD player to know which wire is what.
6/27/2007 8:04:55 PM • Panasonic... • Answered on Jun 27, 2007
My rca preouts doesn't work on my panasonic cq-df802u stereo
The rca plugs can short out. Or one of the comparator that is for audio selection. Might can get away with just replacing them
12/21/2023 3:14:21 AM • Panasonic Car... • Answered on Dec 21, 2023
Panasonic CQ-FN46E0GX No Sound
Hi Greg, I'd say you have a bad audio output IC, generally this will take out the fusable resistor that feeds the output stage, you should be able to find a part number on the IC, do a pin out and check between B+ and ground pins with it in circuit and see if you see a short. I don't know if you can find a service manual for it but hopefully you wouldn't need one
5/31/2023 10:09:12 PM • Panasonic Car... • Answered on May 31, 2023
Panasonic CQ-DF903U CD Player Logo
25 questions posted
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Car Audio & Video
Most Popular Question
cd player in car play cds now when
  • Car Audio & Video
