20 Most Recent
Panasonic Car radio CD CQ-C1110GN CD Player Questions & Answers
Very poor FM receptio, and virtually no AM reception
The cascadia has an integrated AM-FM-WX, XM?, and CB antenna system, that is also prone to poor grounding. The best solution is to install aftermarket antenna systems for all of the equipment... I am driving a 2013 Cascadia with quite poor FM, and non existant AM, and WX reception. The XM works. I am afraid to hook up my CB to this, as it is pushing too much power, and is a sideband unit. I would like to hang the engineer by his/her toenails from the nearest tree for comming up with this garbage...
JVC FS SD96R loses stations as soon as it is
you jvc is not wired properly you must of not had a mecp certified installer put it in... you must make sure on the radio harness that is powering up your jvc that the yellow wire (constant power or battery wire is get 12.0 volts to 13.5 volts at all time even when the radio and car or truck is off. with out this the radio will never save the station or the clock ... if you can do this your self call around to a car audio shop ask if any of there guys are mecp certified installer if not more on to the next shop... and so on if you want me to help you call me i will walk you through it.. i get $35.00 to help you.. 239.560.3498
Set time car radio/cd Panasonic CQ-C13367
First of all, go to service.us.panasonic.com/operman to get the manual for your unit.
With the unit turned on and the clock displayed, pres disp for more than two seconds. The hours will blink... press < or > to adjust hour. Press disp again, the minutes will blink... press < or > to adjust minutes. Lastly, press disp to store the correct time. Good Luck!!!
