Televison & Video Logo
adolfo jimenez Posted on Apr 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant autoprogram digital channels samsung tv hln437w
Douglas Grant
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 53 Answers
  • Posted on Apr 22, 2019
Douglas Grant
Expert
Level 2:
New Friend:
Night Owl:
Answers
53
Questions
0
Helped
19174
Points
168
Digital channels require a digital antenna. Their not too expensive. Wal-mart even carries them. They usually attach to the coax ANTENNA IN on the back of your tv.
5 Related Answers
Anonymous
  • 417 Answers
  • Posted on Jul 06, 2008
SOURCE: the tv says 'check fan
Everything you need to know is right Here
http://www.jangro.com/a/2006/09/29/samsung-dlp-how-to-replace-fan-2/
rallye
  • 23 Answers
  • Posted on Jul 13, 2008
SOURCE: GE 20GT320 TV
don't use auto programme.
use manual or semi auto.
you have to press the auto programme button a few times.
A
Anonymous
  • Posted on Nov 08, 2008
SOURCE: Zenith Z20LCD1
lick on the link below to go to the Zenith page for free manual with details on how to fix your 100 button problem
http://www.zenithservice.com/index_b2c.jsp
ltfrc
Mike Schmidt
  • 227 Answers
  • Posted on Jan 16, 2009
SOURCE: get channel 3 on tv with autoprogramming
When you select channels, the one that comes in the channel number will be green and if you manually select 03 it will probably be red. Hit menu and add channel 03
Nick DelRegno
  • 49 Answers
  • Posted on Jan 24, 2009
SOURCE: autoprogramming
On many televisions with built-in tuners, you have to tell the tuner whether it will be connected to cable or antenna, since the RF spectrum is different for these.  Make sure you have cable selected (assuming you are connecting to the cable service) and then try the autoprogramming again.
1helpful
We have not had this tv on since went over to digital freeview built in hopwever just put it on and there are no channels stored how do we get channels?
Hello
Your TV has to be initilized. It should be retuned to get the channels memorized in its memory section. Then only you can get the channels stored. Hopes that you have its remote control hanset with you. Replace two new cells in it and proceed the folloing steps. Connect ariel to its back socket before doing these.
[1] Press power button on the front panel of your tv. The initial setup screen appears.
[2] Press Ch+ on the remote control handset or on the front panel of your TV to start auto program, or Ch_ button to exit.
The initial setup screen will appear each time you switch on the tv until you perform autoprogram.
To perform autoprogram again
[1] Press Menu button.
[2] Press to highlight Channel Menu
[3] Press Pr Dn button to hilight cable. Press [+] to select.
[4] Press Prog Up or Prog Dn to hilight On or Off according to how you connected your TV. Press [+] to select.
[5] Press Prg Dn to hilight autoprogram. Press [+] to search for channels.
[6] After autoprogram finishes, press "Menu" again to exit.
TO RESET THE TV TO FACTORY SETTINGS
[1] Turn TV on.
[2] Press and keep hold the "Reset' button on the remote control hanset.
[3] Press and release the "Power button" on the TV front panel. The TV will turn itsef off.
[4] Release "Reset Button" now from your hanset.
These are the processes to be done to either autoprogram or turn it to factory settings. Ok.
3helpful
2answers
Samsung HP-T4264 will not autoprogram, locks up on deleting scrambled channels
Reset to factory specifications by turning tv on, and then using the remote, hit power off, mute key, 1, 8, 2, and power on. Interval between key strokes is less than 3 seconds. When tv comes back on it shows Service Mode Display, key up to reset and press enter. Was able to autoprogram without any problems.
Cant program tv for digital
Flat panels wall tv's are digital. Go to menu, set to AIR (do not set to CATV)
Then find the "autoprogram" option and select it. It will scan all available channels
1helpful
2answers
I lost the remote and cant find a universal that is explicitly for this TV - do you know any univeral remotes that will work and what is the code Model Number of Element Electronics TV is FLX3211B Also the...
you can go to menu options, than find programming options.
Look for an option called "autoprogram" and select it. It will search and set all available channels.
There is universal remotes for this tv that you can find by googling "elements electronics remotes":
No cable channels at all on old Sony Triniton
make it sure that the coaxial cable has its own signal! if your tv has a raster (sometimes blue) and it says that the tv is good, but if there's no channel at all then the problem is in digital converter or the connection of the coaxial cable comes from..you can also try auto programing but if the problem still occured then contak your cable subscription channel
1helpful
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Get channel 3 on tv with autoprogramming
No sound, just clicking noise
Is your TV a SAMSUNG DLP TV Model HLN437W Rear Projection Digital HD?
If so I found a TROUBLESHOOTING GUIDE @
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=02010300&model_name=HLN437W
A probably INTERACTIVE ONLINE SERVICE REQUEST FORM @
http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
PHONE #S FOR SAMSUNG:
mobile phones: 1-888-987-HELP(4357)
  • Mon - Fri : 7am - 9pm (CST)
  • Sat : 9am - 6pm (CST)
digital HDTVs: 1-800-SAMSUNG (1-800-726-7864)
  • Mon - Sun : 9am - Midnight (EST)
printers: 1-800-SAMSUNG(726-7864)
  • Mon - Sun : 24hrs
IT Products for Business: 1-866-SAM4BIZ(726-4249)
  • Mon - Fri : 9am - 9pm (EST)
All other products: 1-800-samsung (1-800-726-7864)
  • Mon - Sun : 9am - 9pm (EST)
To see PHOTOS of REPLACING a SAMSUNG DLP TV ballast go to:
http://forum.doityourself.com/electrical-c-d-c/248376-testing-ballast.html
Hope this is helpful.
Good Luck!
Jack iaria
Digital TV Tuning problem
I would try letting the set autoprogram again.
Channel
make sure that ur antenna/catv is properly connected to antenna/catv input of ur tv...better check the center lead if ur using coaxial cable..then try to reprogram/autoprogram ur set.
navigate also on tuner settings...via remote..
if u get nothin after autoprogram..probably bad tuner in ur set..u need a prof tech to fix it...thanks hope this help
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
