20 Most Recent
GE 32GT740 32" TV Questions & Answers
I have an old/new stock General Electric 12XJ4114W television and I need a dial knob for the UHF tuner plus the knob that goes behind it for the fine tuning.
It sounds like you are looking for replacement dial knobs for your General Electric 12xj4114w television. These knobs are used to tune the UHF (ultra-high frequency) channels and to make fine adjustments to the tuning.
To find replacement dial knobs for your television, you can try the following:
- Check with the manufacturer. General Electric may still have replacement parts available for your television. You can try contacting them to see if they have the dial knobs you need.
- Check with an electronics repair shop. An electronics repair shop may have the dial knobs you need or be able to order them for you.
- Check online retailers. There are many online retailers that sell replacement parts for electronics, including dial knobs for televisions. You can try searching for the specific model of your television to see if dial knobs are available.
I hope this helps! Let me know if you have any other questions.
How do I remove the guide plus from coming on at power up?
I found the solution!
With the remote, press the Guide button. This should bring up the Guide Plus+ screen. Press the right arrow to move the cursor all the way to set up and it will ask, "What would you like to do?" Arrow down to "Review Options" and press OK.
The first question is, "Guide Plus+ System Auto Display? On / Off"
Arrow down to Off and press OK.
I have sound but no video
The Television is looking for SVIDEO, which is a separate standard. Since SVIDEO does not provide Audio, it uses RCA audio cables. Try switching to a Video in or AV IN setting.
GE GUIDE PLUS television coaxial cable
Contact the cable provider to know about the signal type they are transiting by it. If it is digital type, you must ahve a set top box to convert it to analogue signals, which your TV can process. It sounds so.
Picture is pulled up.
The chassis used in this series had many problems that were caused by bad solder connections to the metal shield around the tuner. Picture shrinking or moving vertically was a common effect. If no component failures have occurred, resoldering the bad spots will probably fix your TV. Unfortunately, this repair should be done by a professional because it's very easy to do real damage to the circuit board trying to make the repair.
This page has information about the problem and its repair, but it's meant for service technicians and is rather technical. Some other sites have pictures of the areas that need to be repaired and more basic information, but it's still not something you should try without substantial experience. If you want to keep this TV you should probably call a TV shop in your area and see what a repair might cost. When I worked in a shop we charged around $70, but it's been almost ten years now and I have no clue what today's rates are.
