Neither will my computer even see it when plugged in via USB cable. Should I just return it or .... any way, HELP!
SOURCE: how to play music via bluetooth headset in samsung J600
connect the headset...then it will play
SOURCE: My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
SOURCE: I have a centon 2GB Digital MP3 player. I plugged
Remove the battery, then put it back in, restart windows and plug it in,
make sure windows see the devise.
If you removed it while it was still loading, you could have locked the devise
from working, and you will have to send it to the MFG to get it fixed.
Go to there website and see how you have to send it back.
http://www.centon.com/support/warranty/return-procedure
Testimonial: "Thanks!!!! It that worked."
SOURCE: operation failed when receiving a file via bluetooth
don't worry. just make a backup of your personal data such as songs, images, games that are in the memory card. save that backup in your pc or if a have required space in your cell so save that backup there. now formate your memory card. after that replace all your data and then try receiving again. it will work, for sure.
