20 Most Recent VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Questions & Answers
3answers
I Can't find a driver for the following: on the net i lost my installation Cd
Driver for video PM800-M2
7/19/2015 10:30:02 PM • VIA ECS PM800-M2... • Answered on Jul 19, 2015
2answers
I ned vga and audio driver for this board
here is a link to the site just scrool down and the software you need is 1 from bottom of list
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=453&CategoryID=1&DetailName=Driver&MenuID=45&LanID=0 hope its correct
12/22/2013 4:11:50 PM • VIA ECS PM800-M2... • Answered on Dec 22, 2013
2answers
Dont know that how to connect the front pannel switch socket to the motherboard pins for pintium 4 computer
Is it an ECS PM800-M2 motherboard?Uses a VIA motherboard chipset, (VIA PM800 / Northbridge chip, and VIA VT8237 / Southbridge chip)http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=453&MenuID=24&LanID=0If so suggest you download the Motherboard User Manual.Click on the - Download - tab.(Features / Specification / Download / Cerification / FAQ / etc)Click on the blue - Manual(Driver / BIOS / Manual)Go to the Bottom file -English manual for PM800-M2 Release Date: 2004/5/3 To the Right of - Download - click on the country name nearest yours.(Yeah, I know. Europe is not a country, it's a continent)A small window will come up -Opening PM800-M2_10.zipMake SURE there is a Green dot in the small circle, to the left of Save File.IF not; click in the empty circle to the left of Save File.No go below in the window, and click on OK.A small download window will come up.Allow the file to fully download, then DOUBLE-click right on the file name.In the next small window go to the far left, and click on -Extract all files.At the bottom of the next 3 small windows, click on -Next, Next, and Finish.[DO NOT change anything in the second small window.Windows knows where to put the file.Just click on Next ]In the last small window, there will be a red Adobe PDF icon, and the file name next to it.DOUBLE-click right on the file name.You are now looking at a PDF file version, of the Motherboard Manual.The front of your computer is the Front Panel.The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.If you cannot figure out the Front Panel header pinout, post back in a Comment.Regards,joecoolvette
3/14/2013 7:20:31 PM • VIA ECS PM800-M2... • Answered on Mar 14, 2013
Can't get ECS PM800-M2 to boot to SATA drive.
You need to make sure that your SATA drive has an Operating system on it. It can't boot if it only has a data drive.
2/19/2013 6:00:14 PM • VIA ECS PM800-M2... • Answered on Feb 19, 2013
Need a manual for pm800-m2 motherboard
Hello Gerard, my name is Arman (online alias: thedrain)Attached in the below hyperlink is the manual that you are looking for...ECS
1/16/2013 3:33:50 AM • VIA ECS PM800-M2... • Answered on Jan 16, 2013
3answers
P4M800 Pro-M v2.0 sound drivers
for those with p4m800pro m the sound driver is either Realtek ac97 ...or Realtek high definition , and both can be found on a internet search ...if you do not know the kin of audio card ya have , you might take a look in the user guide ...usually is specified there ...( for on board video card ).....for those whom might have a different card ..they also migh try to search for sound-max video driver ...anyway ..its almost impossible to not work with one of these 3...
Good luck !
11/9/2012 3:32:02 PM • VIA ECS PM800-M2... • Answered on Nov 09, 2012
3answers
Realtek integr. audio VIA8237 with ALC655 work
i need driver sound motherboard PM*))-M2 rev:1.0a
11/9/2012 3:25:46 PM • VIA ECS PM800-M2... • Answered on Nov 09, 2012
My sound of my computer does not work...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick ithope this helps you
2/17/2012 12:02:54 AM • VIA ECS PM800-M2... • Answered on Feb 17, 2012
I can't install a 500gb
When you install the drive, go to "Computer" or "my computer" and right-click on the icon.
From the dropdown menu, choose "manage".
Click on Disk Management. You will see your C: drive there and it will tell you what it is.
You will probably also see the new drive, but it will appear as unknown. You can right-click on it to initialize it and format it if it is not formatted.
There you go.
5/9/2011 8:29:11 PM • VIA ECS PM800-M2... • Answered on May 09, 2011
POWER FAILURE AFTER FEW MINUTES
If your power is failing at a few minutes, you could have a bad power supply, power cord, or maybe a bad motherboard.
If you have a spare power supply, try using that and see if the problem resolves itself. Also try a new power cord.
Check that you have configured the connections properly.
If this does not resolve the issue, you may want to return the motherboard for a replacement through ECS or the company you purchased it from.
Thumbs up my solution if it is helpful!
5/4/2011 6:57:56 AM • VIA ECS PM800-M2... • Answered on May 04, 2011
GENX P4800 PRO... mother board drivers required.
http://www.viaarena.com/default.aspx?PageID=2&OSID=1&CatID=1160
click on the model number you will find it in this site then select the windows version you will be able to downlaod the drivers
3/10/2011 6:32:49 PM • VIA ECS PM800-M2... • Answered on Mar 10, 2011
Can you tell what are
This motherboard supports Intel Pentium 4 processors which are made for socket 478.
If you visit this webpage: http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=453&DetailName=Feature&MenuID=24&LanID=0
And scroll down to the bottom there is a list of the CPUs that it supports.
Hope this helps, please rate my answer :)
Chris
3/2/2011 12:10:05 PM • VIA ECS PM800-M2... • Answered on Mar 02, 2011
Vga
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly. Hope this helps don't forget to vote
3/1/2011 7:42:00 AM • VIA ECS PM800-M2... • Answered on Mar 01, 2011
The sound driver
All the drivers for that board are available here
1/22/2011 1:02:46 PM • VIA ECS PM800-M2... • Answered on Jan 22, 2011
My mp800-m2 motherboard doesn't want
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows. Check that there are no CDs or DVDs 3 1/2 inch floppy discs in the CD/DVD,3.1/2 floppydrives. Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
1/21/2011 3:05:57 PM • VIA ECS PM800-M2... • Answered on Jan 21, 2011
I am running with a
u should install sata driver while installing win xp and sata drivers are in built in win 7
11/7/2010 7:18:32 PM • VIA ECS PM800-M2... • Answered on Nov 07, 2010
I have not drivers audio,
What is your OS? go to http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=PM800-M2 and download your driver.
10/7/2010 1:59:02 AM • VIA ECS PM800-M2... • Answered on Oct 07, 2010
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
Popular Tags
77 questions posted
Top VIA Computers & Internet Experts
MegaByteMe
MegaByteMe
Aron
Steve Pack
Steve Pack
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • VIA Computers & Internet
Most Popular Question
not drivers audio
  • Computers & Internet
